Premiere Pro 1.5
How can I create a stereo voice over narration from a mono audio track and duplicate it onto both right and left tracks?
3d Vortex 2 For Premier do not sow in premiere pro 1.5 effect window
Posted on Mar 31, 2011
  • 82 Answers
If you have a mono audio track. You can set the pan all the way to the left, then copy and paste that audio track onto another one, then set the pan all the way to the right. You can set the pan by right clicking on the audio file in the timeline, I forget what you have to click after. But if you can read you should be fine. Just dont click ok on anything that you dont know.
Posted on Dec 02, 2008
How to Record a Song With Pro Tools?
Create a new stereo audio track(command-shift-N) or two mono tracksif using ProTools Free.
Name the track(s), make sure the inputs are set for L-R, or 1-2, or whatever inputs on your interface you wish to use.
Then click "rec" on the track(s) to make them record ready, press command- spacebar, then play your source.
Oct 19, 2016 | Computers & Internet
Hi i have connected the Samson G-track with my macbook. also i using Nicecast & Traktor for radio broadcasting. when i talk from Samson G Track my voice comes only from left speaker. I try the...
This is because the G Track's Mic signal is on the Left channel and the Instrument signal is on the Right channel. You are making a stereo recording when you should be making 2 mono recordings. Does Nicecast have an option to set the track to mono Left channel? Traktor should, but I haven't used it so I can't tell you where the option is. There's probably a Track Input drop-down or something like that.
I am using pro tools 8 LE. I have a blue bluebird condenser microphone. the cable going into the mic is a male 3 pronged end. and the end going into my avid mbox mini is a normal ending (the ones that look...
The mbox mini is usb powered, wont work without power so your mac or pc must be powered on and connected. The blue led will be on when powered. Assuming you have the the appropriate cables, you want to make sure the condenser is plugged into the Mic/Line input. (Input 1 on the back of the mbox mini). All condenser mics require phantom power, so engage the +48V switch. Also make sure the DI (direct input) switch is not engaged. The input gain control is located on the front of the mbox... There needs to be speakers connected to the 1/4 output jacks on the back of the mbox or headphones on the front for sound output. Use the large knob for monitor volume control.
In protools: Create a Stereo Master fader track
Create a mono audio track
Set the input of the mono audio track to Mic/Line 1 Arm the track for record (click & make sure the R is red)
You should getting levels and sound output from your condenser.
Apr 01, 2011 | Blue Microphones Blue Bluebird Condenser...
I am having problems recording with my new Samson G-Track Mic on my Macbook Pro. I use Premiere Pro for voice overs (to do the initial recorder) and Soundbooth to clean it up. I've noticed that my voice...
Start here
scroll down to set up vid, follow the instructions, if it still does not work then call dealer or maker support line.
Hope this helps
Thanks for using FixYa
Hearin myself in just one side of the headset!! help
Make sure when you create a new track in your software, you are creating a Mono track, not a Stereo track.
Create a Mono channel and choose a single channel.
Mar 23, 2010 | Portacom Porta-Com COM-60FC 6 Headset...
Samson G Track USB Mic
To get sound in both channels in Garageband for a podcast using the G-Track Microphone:    select a voice track to record into    make sure the Track Info window is open (blue i button in lower right region of screen)    at the bottom of the Track Info window you will find Input Source:    Change the default setting of Stereo to Mono 1 (USB Audio CODEC)
This assumes you have gone to Garageband preferences and changed the Audio/Midi settings for audio input to USB Audio CODEC which appears when you plug in the G-Track Mike
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
2 tracks
press F4 to open device panel. there you must be able to select inputs and out puts fromyour alesis interface.
be in stereo or mono(check your alesis specifications to know how many mono and stereo inputs it has.
then when you create a new track on the right side of the sequencer window. you must see a input and uut put routing tab
so if you whant to record voice in one track select the inputs where your mic is plug
create a new track and select the other input
so for shure it will say alesis INPUT 1
alesis INPUT 2
alesis INPUT 3
and so on depending on how many inputs your devices haves.
you say it haves 2. but
are they 2 only in stereo
or two in mono
or one mono+one moni+one mono+mono
for a total of 4 inputs in mono mode and 2 in stereo mode.
i dont know witch device you have so i cant tell.
if you have any questions let me know
Jun 29, 2008 | Steinberg Cubase SX3 (502010600) for PC,...
Lexicon lambda
push the monitor button to go mono instead of stereo.
Oct 11, 2007 | Lexicon Lambda Usb Desktop Recording...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
