Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA hdtv: hello, I'm now having the same problem. I just wondered if or how you got it fixed. let me know at cassel3@gmail.com I read that the flyback needed replaced. Does that sound right to you?
  • RCA Master
  • 8,617 Answers
The flyback Number 259296 is available at the following link with free instructions, or they also have the ITC222 deflection board as well which is the board with the flyback on it.
http://servicemanuals.vstore.ca/
Posted on Sep 11, 2008
I have a 52" projection
Bad convergence. Possible bad convergence board(s), or bad connections at flyback on power board along with a little brown/orange fuse by the flyback.
Jan 17, 2011 | RCA HD52W56 52" Rear Projection HDTV
New Flyback old one wont come out
if you dont know what the second anode is you should not be working on this set. on some the lead comes out of the flyback some it has to be removed from the hv distributer block. output transistor probably bad also......
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52
Under the flyback transformer you have cracked solder joints at the legs of the flyback.Also you will see 3 little brown box fuses right next to the flyback.The one in the middle is open and has to be changed out
Jan 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 Flyback Question
The wire comes out by pressing the two tabs in and pulling real hard, You will be happy to know that the replacement IHVT comes with a HV cable since 9 time out of 10 you end up damaging the IHVT cable connection. In any event before checking the IHVT I would suggest looking at CP150, CP120 and CP140 to see if they are puffy, since this is a common problem in this set.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA 52 Inch has a Problem
Brandon,
Your TV uses the 259296 Flyback. You can get one at the following link and they provide step by step instructions with detailed pictures so you can easially do the repair yourself. Heres the link.
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 61 projection not powering on
what is the issue? The flyback is the transformer that generates the high voltage needed for the picture tubes. the itc222 rca chasis can have problems with flyback but they are notoruis to trouble shoot. if if it is you flyback then you will possible have other issue like the horizontal ouput transistor. I work with these alot here at the shop. what is set doing .. does the led flash .. give me some more information and lets see if we can fix this
Jul 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca p60752eb
Sounds like the flyback, can you look on the rear tag and let me know which chassis you have and verify your model number and I will post which flyback you need as well as where to get a replacement with free tech support to help you install it.
Jul 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 flyback question
If your model number is D52W20 you need flyback number 259296 and you can get a new flyback at the following link and they will givce free online tech support to walk you through the removal and replacement procedure.
Jul 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power Light blinks 3 times then nothing
You need to replace the flyback. You need flyback 259296 you can get it at the following link and they give free tech support so you can easily install it your self. Here is the link.
Jul 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WM24 52 in. HDTV convergence IC location
the rca itc222 chasis uses no stk the convergence is controled with transistors... the convergence amp board is located above the main signal board(green board)... it can be identified as the one with several heat sink fins on it. FL231 is related to convergence.. there has been a problem with this fuse when it blows the processor doesnt know it is a projection set so it turns it into a regular tube tv. Here at the shop we have found number one reason this fuse blows is poor solder connection on the flyback. So replace the fuse and reflow the solder connection on the flyback and around that area also the horizontal transistor and then see if that doesnt fix the problem.. if you have an more trouble ..... willie@fordtv.com
Feb 29, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
43 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
