Question about EuroCave Comfort 260 Collector's Package Wine Cellar - Black
Temp won't go down to target
I have four identical units and three are fine.  The fourth doesn't seem to be able to get the temp down below 60 degrees no matter how low I set it.  The thermostat seems to work (the green light goes off above 60) as does the test button (both red and green lights go on).  The only thing that I can see that is different from the other units is that on this one there is a layer of frost on the back wall of the refrigerated compartment, inside, up along where it meets the top of the unit.
  • 833 Answers
Sounds like your unit is low on refrigerant gas.  Too little gas causes rapid boiling of refrigerant and makes the cold spots.  You'll need professional help.
Posted on Nov 12, 2008
My beverage cooler MCBC58DST wont stay cool after it reaches target temp.
Throw it out and get another model from another company. Their units are junk!
They last a year, at best. Them and Magic Chef are one and the same...so you may have to bite the bullet and get a real unit.
Good luck. I speak from experience...I've had four now. Complete junk!!
Nov 23, 2014 | Vissani 5.8 cu. ft. Wine and Beverage...
Why is the unit freezing? It is a TRUE TSSU-60-16.
Turn down the temp and move produce item closer to the front. The air exits the evaporator at around 28 degrees. Possible you need a thermostat.
Feb 04, 2013 | True TSSU-60-16-DS-ST-ADA Dual Sided...
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
Goodman GKS9. I have this unit in a condo that I only use sparingly in the winter. I keep the dual thermostats both at 57 and it maintains that tempeature. The problem is that when the thermostat is raised...
The presure switch is breaking down try taking the tubes off and blowing down the switch , or take a small drill bit and clean inside the connections to the pressure switch some times this becomes blocked .
Jan 16, 2012 | Goodman Heating & Cooling
I have Model: DM30A which constantly freezes up even though it is on a three foot high table and the temperature never goes below 60 degrees
The unit freezing up doesn't surprise me at all. If the temp in your room is 60 degrees then the temperature of the air will be around 40 degrees and the coil is about 20 degrees. Your expecting to much, the tempature is to cold to work properly.
Jul 08, 2011 | Haier Dehumidifiers
I recently purchased a used ac for my rv. it has two and one had gone out. the air coming out of the new one only gets down to 60 degrees while the air out of my old one is 50 degrees. they are both the...
No it means you 50 degree one is working better than perfect. Clean the one that is only getting down to 60 degrees but remember if a unit is dropping the air temp by 20 degrees its working fine. You ck this by cking the air at the intake where the filter is say temp is 80 degrees and then take a reading at a discharge vent where the cold air comes out if its 60 you have a 20 degree drop and that is considered good. If the unit was low on freon the unit will freeze up (ice will form on the inside coil).
Aug 10, 2010 | Dometic Rooftop RV Air Conditioner
My brand new HVAC unit is not able to maintain the heat in the house. The unit itself seems to be running fine but there was an accumulation of snow and ice on the fan unit. When I knocked all the snow and...
i hope the air condition is feet to your home ,if u have ceiling tall
the heat will stay high point ,and the air condtion will be on most of the time. if not
and the mode is heat
firrst:
clean the filter in evaporator (out side the house).
check and see if the engine of the evporator work and runing.
without wibrtion.
but the main reason is most unit hvac are not inverter,
so that mean if the tempratore out side is beneed to 5 degree Celsius (most of the time night) the unit will be frozen.
60 degrees f = 14 degrees c
you can defrost the buy chnge to mode cool.
other cohice ic to check the dieicer if u have it.
Feb 05, 2010 | Goodman Heating & Cooling
G E oven temp fluctuation
No, that is just fine. As a matter of fact, older ranges often had 50 to 60 degree swings in temp. Your oven temp (assuming your thermometer is dead on accurate) is 347 + 365 / 2 = 356 degrees when set at 350. I never mess with ovens which are within 10 degrees of set temp. (when checking the temps, make sure to take the readings after the oven has cycled on and off at least three times, and use a good digital oven calibration thermometer)
Mar 18, 2009 | Kitchen Ranges
EuroCave Comfort 260 Collector's Package Wine Cellar - Black Logo
585 people viewed this question
Top EuroCave Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you an EuroCave Furniture Expert? Answer questions, earn points and help others
