Question about Sony KV-27S15 27" TV
Sony KV 2084R
Some channels are snowy some aren't - some I can't bring in well enough to watch.
  • Diane Csrnko May 25, 2006
    If the tuner is bad is it worth fixing?
    President:
  • 3,130 Answers
Is this set attached to cable?? have you tryed another set in this sets place first??? if so then the tuner on the sets probably bad but make sure the signals good on another set and not just on a default cable station on the tv like channel 3 or 4 .If another set looks crappy too then call the cable company.. if its on an outside antenna(do they still use those LOL)then see what others in the area are getting for reception. sorry My friend I cant answer any farther till you come back with more for me in my questions.
Posted on Mar 26, 2006
  • Larry  Dillon
    Larry Dillon May 25, 2006
    This set is a very nice model BUT how long have you had the set? How did the picture before it went out. Does the set have all the features. Do you like the set? These are questions you have to ask yourself. The tuner got this model is available at www.partstore.com at a cost of 77.78 usd. the part # is 859825400. if you know someone with electronic experience this is not a hard part to replace BUT im against a do-it yourselfer trying to get into a tv set to save a few bucks when they can be killed or seriously hurt! Good Luck
SOURCE:
I have a sony 27 Trinitron with tuner issues. the picture is fuzzy/snowy on most channels. I have inspected the cable coax and it is not an issue. the problem started shortly after an electrical storm. I...
The RF amplifier in the tuner has been damaged. You will need to replace the tuner. A suitable replacement tuner from a wrecked Sony tv would be you cheapest option.
Best regards Vintie
Oct 08, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Can not change channels. the image is snowy. dvd's play great.
The problem on that aspect is on the tv internal tuner section,on 33volts dc supply,,cause by the a shorted zener diode...,Dods
Sep 19, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Automatic tuning has lost all the channels
have a service tech check your tuner section for problems. are these channels snowy? if they are it is most likely no or limited amount nof frequency or not enough voltage going to tuner. this could be caused by a resistor or diode problem.
Nov 06, 2009 | Sony Televison & Video
Snowy picture on VCR with only certain channels
In all likelyhood, you have a bad ground somewhere in the cable. Try other channels through the VCR. If the ground is the problem, there will be a cluster of channels that are snowy with the rest being clear. Check the cable itself and all of the connectors along it.
If the cable and connectors are good, the tuner or power supply of the VCR could be faulty and cause this as well.
Dan
Dec 24, 2008 | Sony SLV-N50 VHS VCR
SONY TRINITRON MODELO KV-21XME
If its a digital television and has a remoten sensor just buy a universal remote and configure it to your TV.
If it responds then you can search and store the channels you missing.
Thanks
May 07, 2008 | Televison & Video
1996 RCA Color TV model G27720tn
If you are on cable, first run the cable wire from the wall directly to the TV, eliminating any cable box and/or VCR. If channel 2 is snowy but the rest (especially 3-6) are clear, it is most certainly a cable problem and not a TV problem. The TV uses the exact same circuits for channel 2 to 6 (VHF-LOW) so if the tuner was bad and 2 was snowy, 3, 4, 5 and 6 would be snowy too. Bring a second TV into that room, disconnect the cable wire from the RCA and connect it to the second TV. Is channel 2 on the second TV as snowy as it was on the RCA?
Aug 18, 2007 | RCA 24V511T 24" TV
Intermittent snowy pictures under Channel 51
Probably needs a new tuner or something associated with the tuner.
May 31, 2007 | RCA F36673ET 36" TV
Televison & Video Logo
131 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
