Question about Tomtom GPS
Battery flat & will not hold its charge. It cuts out every few minutes.
  • 66 Answers
Batter is dead. You'll need to find a replacement on line. Detailed instructions (with photos) are also available there.Just print them out .
Posted on Jan 29, 2010
Our Super Gaucho 24volts is 2-years-old and barely used. Now the battery is not lasting to long. Is this normal? I mean, with a more frequent charging/use will its performance be improved? Thx ahead &...
Unfortunately the batteries just lose their holding power after awhile, and if you don't keep them charged every few months (like during winter if your child isn't riding, you still need to charge / refresh the battery every 2 months or so, if it isn't charged for a few months, it'll lose some of it's holding power), that's a very common problem. Our 24V Perego batteries for our Gaucho only seem to last like 30 minutes of constant riding (my son rides non stop sometimes for 30+ minutes). If you check out the site modifiedpowerwheels.com , people convert them to use non Perego batteries that run for much longer!
Nov 01, 2010 | Peg Perego Gaucho Superpower
1985 ford LTD - replaced alternator & battery, checked wiring OK. Car will start but cuts a few minutes later, also not holding a charge.
Are you sure that is a charging problem?Check if the carb injects gas at the moment the engine runs off,if there is spark on the ignition cables,as for no holding the charge,make this tip,disconnect the positive cable of the battery and get a multimeter,connect one terminal to the battery post and the other terminal cable,and disconnect every fuse and relay and possible part that consume a charge,one part at the time,when the reading on the multimeter goes down you did find the problem that its consuming the charge.
Sep 29, 2010 | 1985 Ford F 250
How do I charge my 300 from flat
remove the battery and fast charge it.
To fast charge a battery, get an adapter that is between 4 - 9 volts, cut the wire and place the red part to the positive part of the battery and the black, to the negative part of the battery.
Use your hands to hold the wires to the battery for about 2 to 5 minutes. By then the battery cell must have been boosted. Then you can continue the charging with its real charger.
I wish you good luck
Mar 18, 2010 | Amcor 3900 GPS Receiver
Stupid phone and phone charger
your battery might be fully flat,now take a battery eliminitor & set it to 4.5 volts then connect - &+ terminal to the dead battery 4 the few minuts,put battery back into the cell phone connect charger do not power on the cell,if every thing is ok then charging should start.
Jan 08, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Grass hog 18v nst2018 trimmer
Sounds like faulty batteries , take it back to the store where you bought it.
Aug 26, 2009 | Black & Decker String Trimmer Cordless 12"...
Afterjump off car want hold charge
Battery is probably bad, even Walmart can check the battery in a few seconds. Go from there.
Jun 12, 2009 | 1993 Saturn SL2
Hitachi 18v recip saw just quits.....battery life or saw problem?
You are ok with what you got. The cordless saws take a lot of power to cut wood so it drains the battery fast. I have the ridged setup and my battery on a full charge only gets 4 cuts on a 2x4 befor it is dead. The saws will not give you any worning becauase the teath of the blade will get stuck in the wood so it just will not slow down like the drill will. I hope this helps with your ?
Dec 31, 2008 | Hitachi 18V Lithium Ion Cordless Hammer...
Rechargeable Camping Lantern
you need to coldsolder the pc board.
Apr 09, 2008 | Dryers
GPS Logo
35 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
