Question about Sony KV-27S15 27" TV
Sony KV-27S15 won't receive all channels
The tv only receives a few of the cable channels. There does not appear to be any rhyme or reason as to which ones it will receive. Should I toss it?
  • Diane Csrnko May 25, 2006
    If the tuner is bad is it worth fixing?
    Problem Solver:
  • 12 Answers
IF NOT SODER, THE E-PROM COULD BE BAD.
Posted on May 25, 2006
    President:
  • 3,130 Answers
These sonys are common for tuners. What are the channels you are getting?? Are they all in a line like 2-3-4-5-6?? 7-8-9-10-11- 12 -13?? so on and so forth.cold solder connections on the tuners are also a problem sometimes
Posted on Mar 25, 2006
  • Larry  Dillon
    Larry Dillon May 25, 2006
    this tuner cost is 77.78 from the partstore.com. part # is 859825400 If you like the set and it has all the functions you want then maybe it would pay to replace it if you could get an honest repair person. Or a friend thats good with a soldering gun as this is not a hard part to replase But in a shop it shouldnt cost over 2oo or 225 usd
Can not tune tv since change over
The KV-32FS100 only has an analog tuner (NTSC). Unless there is a low-power analog station still broadcasting in your area, you will not be able to watch OTA stations. (I've got one in my area that barely comes in.) If your local cable still sends an analog signal, you won't need a set top box to watch that subscribed service.
Otherwise, you need a set top box to watch TV. A digital to analog converter (the boxes that were available with the government coupon before the switch over) will give you over the air stations. The basic models only provide SD output; there are a few HD models available. Otherwise, you can use a satellite reciever, cable box (for digital cable service), or something like the Boxee or Sling with tuner. (There are a few different models of the Boxee; one added a tuner with a USB dongle. The newest model of the Boxee has the ATSC tuner built in.)
Note: OTA digital signal quality is either a strong enough signal for the tuner or no signal will be present. You need to point the antenna in the correct direction to receive the signal from your local transmitters. The type of antenna and its placement will also change the number of watchable channels. You can use antennaweb.org or tvfool.com to get more information. Antennaweb assumes an outdoor antenna but gives a conservative list of stations. If the signal is split to several devices, you may need an amplifier to get a watchable signal. (Sometimes amplifiers fail and you won't receive any stations, so test without the splitter or amplifier by using a direct cable to one TV.)
I hope this helps.
Oct 26, 2012 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony pre-LCD 32" receives power and directly
I would take your A/B switch out of the line. And get yourself a good reciever to channel every thing.
Jan 04, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No Power Problem with KV-27s15 Sony TV
Barry, remove the back cover by removing the screws with an arrow next to them. The fuse is located on the left side as viewed from the back, where the power cord connects to the circuit board.
Aug 09, 2009 | Sony KV-27S15 27" TV
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
SONY KV-27FV310 FINE TUNING
AUTO PROGRAM YOUR CHANNELS. IF PROBLEM PERSISTS REPAIR OR REPLACE TUNER.
Nov 03, 2008 | Sony FD Trinitron WEGA KV-27FV310 27" TV
UHF Tuner
Check to see if the TV/CABLE setting is on CABLE.
Jun 05, 2008 | Sony KV-27V42 27" TV
Sony KV 2084R
Is this set attached to cable?? have you tryed another set in this sets place first??? if so then the tuner on the sets probably bad but make sure the signals good on another set and not just on a default cable station on the tv like channel 3 or 4 .If another set looks crappy too then call the cable company.. if its on an outside antenna(do they still use those LOL)then see what others in the area are getting for reception. sorry My friend I cant answer any farther till you come back with more for me in my questions.
Mar 25, 2006 | Sony KV-27S15 27" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
