Question about Riso RZ220 Duplicator
Risograph Drum I have a Risograph RP3100 that we have not used for a couple of months. When we tried to use it there is what I would call a dry spot on the drum and the text in that area does not print. I tried pulling the master back and rubbing the area with alcohol but that did not help. Any ideas????
  • Anonymous Sep 18, 2008
    i have the same problem with CR1630. was the problem resolve with the suggested solution?
  • RichMcA Mar 11, 2009
    I haven't tried this yet but sounds like best idea yet.
    Get a can of WD40 and spray it under the master, then rub the area with your finger. this will desolve the dryed ink on the drum surface.
    I'll try it soon. richmca@msn.com
    Problem Solver:
  • 19 Answers
Try run a hundred copies at slow speed and full density/ pressure.
If that fails get a can of WD40 and spray it under the master, then rub the area with your finger. this will desolve the dryed ink on the drum surface.
Dermot
Posted on Mar 08, 2009
  • 81 Answers
Run a lot of copies.. when i mean a lot i mean a lot it can take about 1000 or more copies..
Posted on Sep 12, 2008
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
Hello I have to run a risograph tr1510 that have not been used for a couple of years or more. The drum are completely dry. I read this post: http://www.fixya.com/support/t4515933-risograph_rp3700_not...
I don't think WD40 oil is the best solution.
I had to do such a procedure a few months ago. - I got a drum which was not in use some month. This is normally no problem with original ink. But some cheap plagiators have their own ink recipe.
I used a solvent for professional offset printers. It is the one to clean the ink rollers with. it was blue colored and I think it is so with most manufacturers. (I have seen some brands for this purpose and all were lighter or darker blue.)
By the way, it isn't so easy as it seems: The drum looks clean enough after some time. But to remove really all of the hard and gummy ink inside I had to take the drum apart. It took so much time and was so dirty so I will do this again only if I get paid accordingly.
Dec 31, 2010 | Riso RZ220 Duplicator
How much rinse aid do I put in my dishwasher and how do I use the arrow within the rinse aid dispenser in the machine.
The dispenser will take about 6 oz of rinse aid if completely empty. It will only need filled every couple months depending on how often you do dishes.
If you are getting poor drying performance or spotting use a rinse aid that is called 'Turbo Dry'.
The arrow is how much rinse will dispense each load. Start out near the center, if you see spotting or turn it up slightly and try another load.
Aug 22, 2010 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Have a Risograph RP3700 that we have not used for a couple of
try cleaning the dry spot with WD40 or penetrating oil to melt down the ink
Apr 08, 2010 | Riso RZ220 Duplicator
Risograph cylander is jammed. It is ajar but won't come out or go in. I think the film did not complete it's loading to make a master. Parts are not where they should be. How can I get the cylander back in...
The drum cylinder of any risograph has a locking position. The drum position should be locked on before puting it back on the machine. After you confirmed the proper position and tried to putting it back and still no progress you do the following.
1. Removed the drum unit from its holder.
2. Use flash light and check inside of the machine. Check a shsft in the middle part of the machine where the drum put on.
Check the position of this shaft and the position of the drum hole where this shaft will put on.
3. Try to rotate this shaft according to the position of the hole of the drum then try to return the drum and put it back again.
4. If the drum won.t go in just half way, removed the drum and check the pressure roller position, if the roller are in highest position This roller in under the drum. If you see it blocking the drum removed the back cover and released the hook lever from pressure lever. You can see this by moving the roller and you will noticed its position,
Jan 07, 2010 | Office Equipment & Supplies
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Rp 3100 Drum Problem
You can clean it, thats a good idea but,,(and this is messy) roll back the master.. take out the ink cartridge, use a rod to squeeze some ink onto the area, and smooth it out into the screen with a plastic scraper.. Lay the master back over. Keep scrap paper around and print a big black square and run a couple hundred sheets through.. This will work. Messy but will work. If you don't want to manually put some ink on the area.. Print a large black square and run a couple hundred sheets.. see what that does.
Sep 10, 2008 | Riso RZ220 Duplicator
1,132 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
