Question about Whirlpool Duet GHW9150P Front Load Washer
Drainage where is the drainage filter at i have the f21 code
  • 1 more comment
  • siony40 Oct 12, 2008
    I had the same problem, I drained it this morning for my wife and right after she started another load but error f33 occured? Not quite sure what s going on here!
  • colormekaren Dec 01, 2008
    I have the same problem... going to try the fix it suggestion.
  • chamm1956 Jan 12, 2009
    My washer will not drain and shows f2 as well as suds. How can I fix this? Do I need a repair man or can I fix it. Please help me.
Turn off the hot and cold water supplies and remove the power supply cord from the outlet. Remove the lower front panel by removing three torx screws, one located at the lower left corner, lower center, and lower right corner. The panel removes easily. Located at the bottom center of the cavity is a large ivory colored filter with a turn cap. Get a shallow container or alot of towels, and slowly turn the slotted cover to the left a little at a time until no water runs.  Remove the filter and any debris that may be inside. Wash and dry the filter and replace, tightening the cover securely. Replace the lower panel, turn on the water supplies and plug in the power supply.  This should solve your problem and also relieve any standing water in the drum following a wash.  You may want to do this every 3 months or so as this is an easy fix
Posted on Sep 11, 2008
Maytag washer mfw9600sq0 f21 code blinking and wont do anything but blink after replacing pressure switch. Pump was also replaced. Pulled the plug for 30 secs to try and reset but still continues. The...
"F21" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. More than likely the filter is clogged up. Remove the bottom kick panel to get to the filter. Have some towels handy since there will be a bit of water that will come out when you open the filter. Take a look at the video above to show you how to access the pump filter.
Sep 26, 2013 | Kenmore Elite 45986 Front Load Washer
He2 plus front load washer keeps showing F21 error code. I cleared the drain pump filter. Still displaying F21 how do i check to see if i need a new pump
If you found a blockage in the pump screen restricting the drainage and it now drains fine but F21 is still there,the error code can be cleared by pushing the PAUSE/CANCEL 2 times within 2 seconds.
If after clearing the error code if it returns on the next wash cycle the pump will need to be replaced.
I hope this has helped you resolve your washer troubles,
Gene
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
My machine is stuck on f21
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
F21" is a Long Drain error code which is usually an indication that you may have an obstruction somewhere in the drainage system. Most commonly, there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean.
You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: A "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Take care.
Jun 27, 2010 | Washing Machines
Display F21 on panel
"F21" is a Long Drain error code which is usually an indication that you may have an obstruction somewhere in the drainage system. Most commonly, there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean.
Take care.
Jun 25, 2010 | Kenmore Elite 45986 Front Load Washer
The screen says f21 and does not rinse cloths out
If this is a Kenmore Elite, Maytag Epic, or Whirlpool Duet front loader series washer, "F21" is a Long Drain error code. This may be an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can commonly clog in this area as well causing the drain cycle to fail.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Feb 25, 2010 | Washing Machines
Code F21
"F21" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
NOTE: The "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
Dec 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F21 ERROR CODE ON MAYTAG FRONT LOAD WASHER M#MHWE500VW
The newer model Maytag washers are manufactured by Whirlpool and have Whirlpool parts. If this is a Maytag Epic model washer, "F21" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as sock or under garments can commonly clog in this area as well causing the drain cycle to fail.
Dec 21, 2009 | Kitchen Ranges
"f21' on my kenmore elite washer
"F21" is a Long Drain error code. This indicates that you have an obstruction somewhere in the drainage system. In most cases, this means you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
You may have something getting caught in the pump impeller and slowing it down. Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUDS" error can also commonly occur with the F21 error code as this is can be generated when air is sensed in the drainage system.
If you have any questions, please let me know. I hope this helps you.
Oct 16, 2009 | Washing Machines
Washed a rug. Error code F21 came up when washer
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. In most cases, this means you probably have a clog in the drain pump. The following link explains:
Rugs are notorious for losing fiber and holding loads of dirt. You may have something getting caught in the pump impeller and slowing it down. Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUDS" error can also commonly occur with the F21 error code as this is usually generated when air is sensed in the drainage system.
Oct 15, 2009 | Washing Machines
F21-drainage problem
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 23, 2009 | Kenmore Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
184 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
