Question about Polaroid 3211TLXB 32 in. LCD Television
Picture Size The picture on our 3211 TLXB is larger than the physical frame of the screen. Is there a way to adjust it so that the received picture falls within the borders of the physical frame of the screen?
  • eberry78 Dec 31, 2008
    I have a 40in and it's doing the same thing...can't see the whole picture.
How do you change the setting to auto or panorama - the cinema didn't work.
Posted on Dec 29, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Check your picture setting if it is on zoom, you can set it back to auto cinemal or panorama
Posted on Oct 12, 2008
How do I adjust the screen size so that it fills the screen and not be any larger.
You're going to have to go into the settings screen going to your picture adjustment and adjust the picture from there
Feb 07, 2018 | The Computers & Internet
How do i adjust the picture to fit thescreen on my toshiba flat screen tv
Hi, T
There will be a key on the remote control to adjust the picture size. You can adjust the picture size of your choice using this key.
Oct 11, 2014 | Toshiba Televison & Video
Polaroid 3211-TLXB has funny colored picture quality. Turns on and off fine and sound is fine.What could be the source of the problem??
Sounds like T'Con board fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Aug 30, 2014 | Polaroid Televison & Video
Polaroid 3211-tlxb have power and sound but no picture. It did smell like smoke. Any recommendations? Unit is 2 years old.
If you can see a picture (dim and low contrast) when you shine a light on the screen from an angle, your backlight inverter may have a burned-out part.
After this test, whichever result you get, unplug the set and use your eyes and nose to search for overheated parts. I have found connectors that overheated because of a poor-quality solder connection on the circuit board. Note that parts, particularly resistors, can overheat because of a fault in another part.
It is common for solder connections to deteriorate if they are frequently run at high temperatures. Sometimes circuit boards "normally" turn brown from heat because of marginal thermal design. Check the solder connections on components in the hot areas.
Static electricity precaution: most digital electronics are easily damaged by static electricity discharge. Avoid touching the metal parts of the circuitry unless you first touch the metal frame of the set to discharge any voltage buildup on your body.
Nov 10, 2011 | Polaroid 3211TLXB 32 in. LCD Television
My picture is larger than the screen. How do I get the picture to match the screen? ---Dave---
Look for a buttons in ur remote like Aspect Ratio,VIEWMODE,P.size push and used one of these buttons on the remote,will be able pick the picture sizes that will fit ur tv screen frame.
Dec 03, 2010 | LG Televison & Video
I received a GE model no. 27956FE1-A as a gift over a year ago. I put some pictures on the digital picture frame then. Now that I want to add some, I get a message that the pictures are not compatible. ...
I have discovered the problem
There is two things. First that the memory card used cannot be more than 2 GB and second that each image file cannot be larger than 2 MB. My photos where much larger than this and I discovered in the manual that it "hints" to pictures being 2 MB in size, I re-sized my pictures and no longer received this error. hope this helps.
Aug 17, 2010 | Uniden Cordless Phone
Zenith 32" TV picture is larger than the TV screen size.
Adjust the Aspect ratio. The manual will tell you how.
Feb 02, 2010 | Zenith A32B84R 32" TV
Picture size
Hello! You need to put your tv into service mode and adjust the horizontal and vertical size. You can find info on how to enter the service mode for some brands at Good luck.
Oct 10, 2008 | Televison & Video
JVC AV2649S Picture Too Large
you can see the diagnostic menu in jvc as you press both at the same the display and the picture mode buttons
Oct 17, 2007 | JVC AV27F476 27" TV
Polaroid 3211TLXB 32 in. LCD Television Logo
160 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
