Question about Whirlpool Washing Machines
I have a whirlpool duet sport washer front loader and this F-21 comes up in the display and the washer stops and the door is locked help
  • 5,911 Answers
"F21" is a Drain Problem error. If you press PAUSE/CANCEL and it does not correct the problem, you will have to perform the following:
- First of all, the manufacturer recommends unplugging the washer for at 30 minutes before assuming you have a component failure. In some cases, this is all that is required to clear common "glitches". If the problem can't be a explained away as a momentary computer related problem, then continue below:
- Inspect the Drain Pump for clogs - the following link explains how:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
- Inspect the drain hoses for clogs - this includes the drain line that runs from the bottom of the wash tub to the inlet side of the pump, as well as, the drain hose that exits the puimp and runs to the standpipe at the wall.
- Inspect the drain hoses for kinks.
If the error code still persists after you perform all these preliminary measures, it is recommended that you replace the drain pump. It does not take much to damage the drain pump in this washer. If foreign objects remain in the pump for extended periods of time, it can potentially damage the impeller and motor. The result will be a drain pump that APPEARS to be running, but isn't pumping water like it should. If the pump is damaged, please let me know and I can assist you with locating replacement parts. The cost is usually about $100 or less, if you perform the repairs yourself. I also have step-by-step instructions if needed. I will need to know your MODEL number if this is the case. Hopefully, it won't come to that. The answer is not spend MORE money on another appliance. You can learn through expert advice how to repair your appliances yourself and avoid the expensive service call. I hope you agree.
I hope you find this information helpful. If you require further assistance, please let me know.
Posted on Sep 11, 2008
The correct answer is to refer to the tech sheet inside the washer. It has all the error codes and troubleshooting advice. No need to buy a new washer when you have to ability to read. Unplugging the washer for a few minutes will NOT correct this problem!
Posted on Sep 10, 2008
    Novelist:
  • 166 Answers
Peace Friend,
ngafm At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT.
If not only a trained laundry tech can make the electronic diagnoses.
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Thank You
Posted on Sep 09, 2008
F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code reading f 21, whirlpool, front loader, washer, duet sport
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Mar 03, 2010 | Whirlpool Washing Machines
Door lock error whirlpool duet front loader
DO NOT BYPASS A SWITCH UR HOUSE WILL BE FLOODED INS WILL NOT COVER IT. YOU NEED A DOOR LATCH, AN MMC AN PROB A BELLOWS CAUSE YOU WILL RUIN IT PUTTING THE SPRING CLAMP BACK ON. DO URSELF A FAVOR AN CALL A SERVICE TECH
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My front loader washer whirlpool codes fdu and the door won't unlock.
F/dU error means --------- Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error. -------- to resolve the error --------- Door Lock Mechanism broken. globul1a.gif Check Door Lock/Switch Assembly for foreign objects globul1a.gif Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
Apr 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
85 people viewed this question
Dan Webster
Dan Webster
prem mathew
