Routers
Problem for Routers
Generic problem for all Routers
Dell inspiron with netgear netwok card. won...
By tareqmsi on Sep 09, 2008
Hi i recently moved home. My dell inspiron computer did not have a built in wireless connectivity. so i have been using this Netgear PCI card (? the ones that are like a thick creidt card size and u slide in the side of ur laptop) for the last three years with different wireless routers with no problem. But this time the SpeedTouch router connects with this laptop. But in the connection properties it shows 'packets received'= zero while 'packets sent' goes up with time. my laptop recognises the router, and the connectivity icon at the bottom right corner of the screen is green and everything. but it just wont connect to the internet while other computers are doing fine at the same time under the same router.
I found out that the router does not assign any IP, DNS, WINS or Default Gateway numbers to my laptop, while apparently it does to other computers in the network. I have tried to copy those numbers and manually input in my laptop, (of course changing the last bit of the IP with an arbitrary number) but nothings working.
WEP security is enabled and it takes in the password without any error message.
Any help would be much appreciated.
Comments:
Sep 10, 2008
- i have let windows control the wireless network instead of the NETGEAR application that was doing it so far. This has solved the problem for now, but after several tries. I'm not sure windows is getting it right every time. Sometimes it assigns my laptop subnet mask 255.255.0.0 and it doesnt work, other times its assigning 255.255.255.0 and then its fine!
Thanks P Singh for trying.
Best Solution
posted on Sep 10, 2008
Helpful)
Pritpal Sing
Rank: Guide
Rating: 87%, 7 votes
Try reinstalling the drivers for your wireless.
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
What port number is associated with the printer port? I am trying to use the USR5461 router with... (More)
Answer
can't get the wifi to set up on wrt160n. it keeps failing. all wired computers are fine though.
Answer
I recently bought a D-Link WBR=2310 Rangebooster wireless router. The installation disk is only for... (More)
Answer
I bought an Encore 802.11n Wireless Router ENHWI-N2 so that my family's laptops can connect... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 3663
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
