My Maxent plasma stopped recognizing the rgb input???? It changes from blue to black, but stops there and never shows anything except a black screen. I have tried two different cables and two different computers.
    Genius:
  • 1,847 Answers
Did you check on different AUX. what are you connecting the tv to?
Posted on Sep 09, 2008
    Brigadier General:
  • 5,158 Answers
Any lights still on the front of the tv to indicate it is on ?
  • Roberta Smith
    Roberta Smith Sep 09, 2008
    As this is a premium question i'm compelled to answer your question here and not as an ask me question. if the green light is still on it suggests an internal issue, likely a blown capacitor or a power supply issue. if you are not comfortable with taking the tv apart i would have to suggest you have it service at a capable electronics repair shop.
    Robert
    please take a moment to rate this solution. thanks
What is rgb
RGB = Red, Green, Blue (Y, Pr, Pb) or the Component video inputs. Component is the highest resolution analog video input on your TV & unlike HDMI only carries the video information.
Feb 14, 2013 | Maxent Televison & Video
In RGB mode I get only green display, all other inputs are normal.
Digital board or analog board... i need to know more details..
please send more info if you need more help
Feb 09, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Vertical black lines appear intermitently
Does the line appear on just one input(cable,hdmi,video1,video2,ect) or on all of them? The reason why I ask is it may be just an issue with one input setting on the television and you may be able to use a different input for a temporary fix of the problem. Plasma telivisions run very hot and it may be overheating. Try using a small mountable fan above the TV pointed into the back heat vents and see if keeping it cooler keeps the issue from happening. These TVs are repairable but usually cost more to repair than what it is worth due to plasma TVs are very in-expensive now.
Sep 04, 2009 | Maxent MX-42V1 42 in. Plasma Television
Maxent mx-42vm11 screenflashes black and acts like it loses input
Check on ebay for the repair kit if you are versed with a soldering iron.
Apr 09, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Picture problem with Maxent Plasma MX-42HPM20
Very common problem on these sets caused by bad surface mount caps. Check on ebay for a repair kit it's the only place I know where one exists.
Feb 23, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Hooking up a Mac to tv
I ran into the same problem with my "50 maxent. The manual clearly states that mac resolutions are not supported. We won't let that stop us. Step one is to download switchresx. It's a simple utility that should allow you to define custom resolutions. http://www.madrau.com/ .
Step 2 is to download chicken of the VNC. http://www.macupdate.com/info.php/id/9517 . Once this is installed on a separate mac from the one you are trying to connect to the maxent take your mini and hook it up to the RGB port on the maxent and boot it up. Once this is done use chicken of the vnc to take control of of the mini with the other mac. Now you can change the resolution on the mini using switchresx which you installed on the mini earlier. In the case of the maxent you will need to set it to 1366x768 at 60 hz. If using another flat panel consult your user manual for the correct resolution. In my opinion there is no flat paned tv this should not work for.
Sep 30, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Another question about maxent plasma monitor
Yes problem is repairable sounds like the mainboard (video) needs replacement because the rgb is part of this board along with the rest of your inputs this should fix your problem. There are some models where rgb is seperate but not many I will need the model number of your Maxent to be of further help.
Sep 09, 2008 | Televison & Video
How do you hook the up
Use the instructions that came with the device for full details. Their site is down, so you can't get a manual online at this time.
Usually, all you need is video input (a cable connection) and power.
If you have a straight cable line (no box), coax cable connection is will work if supported.
If you have a box, the better cables support the RGB and audio split, and will give you a better quality picture.
Be sure all are secure connected, and that if you use the RGB/Audio split connection, be sure each matches the color coding on the connector.
Jun 09, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent as PC monitor
Most likely you haven't set it up as a mirrored display. Try dragging your mouse off the edges of the original dispay (or laptop screen) and see if it shows up on the plasma, if it does, figure out of to mirror. Im not sure how to go about mirroring the display on windows, but on mac its an option in the display drop down menu.
Mar 16, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
