Question about OKI KIT-C3530N MFP LASER CLR P/S/C/F USB ENET 1200X600 128MB Printer
Toner sensor error after replacing cartrige...
Hopefully this will clear up a little confusion I had:
1. Follow instructions for replacing toner cartridge.
2. Remove drum from printer. Take care not to handle the drum surface. Look for a small rectangular window or depression. The window will be completely or partially blocked by a flap.
3. Use a fine pointed instrument to move the flap up, so that the sensor underneath is visible.
4. Replace the drum. The error should clear after the print engine has reset.
Posted on Jan 26, 2009
    Sniper:
  • 97 Answers
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
toner sensor error - 0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
Posted on Dec 07, 2008
Sounds like you got a bad toner cartridge. This happened to me and when I put in a new toner cartridge everything work fine and no errors. Take the toner back where you bought it for a replacement.
Posted on Jan 21, 2011
Soulvisitor
  • 1113 Answers
SOURCE: toner sensor problems
On the base of machine after removing drums and transport, there are 4 sets of 3 pins that connect to left hand bottom of each drum, these can get toner on them and not make proper contact, each set of 3 pins just pop out with the help of a flat blade, out of base to be cleaned. in yout case just switch the set under the cyan with another lot from different colour.
I am taking it that you are using genuinne non imported oki drum and toner. If this doesnt fix your problem then you must have fauly drum/toner
Posted on Nov 13, 2007
Benimur
  • 6966 Answers
SOURCE: printer sharp ar-m155.keep showing me
with the indulgence of the others....
Pls recheck how the micron corona wire is attached to the printer, it may be corroded and therefore would require scrapping/cleaning. Additionally, is it the same gauge/size as the original/old wire?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 01, 2008
  • 300 Answers
SOURCE: infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
Posted on Jun 09, 2008
  • 4 Answers
SOURCE: Toner Sensor Error - Cyan. I got this error after
If you have a lexmark disregard this because their printers wont reconigze most refilled ink cartriges even if its done by proffesionals such as wal-mart est. (warranty also does not cover refils you'd need to buy a new one) what you need to do is take it and get it checked to see if they put the coulor ink in right if they did, then gently wipe the sensor on the printer, and the brass part of the ink cartridge above the ink part, put it back in and see if that works. And lastly go to your printers driver and see if you can reset the toner levels from there manually, if you cant try turning off the sensors or tricking it (google various methods) or buying new cartridge
Posted on Apr 23, 2009
SOURCE: replaced toner cartrige and the error message
Try this.. It worked in my Brother MFC 7320.. SO it May work.. Open the cover. Remove Drum and Cartridge. Look inside. There are 2 LENS ON both sides. Cover the lens with a tape. Replace Drum and Cartridge. Click cancel. then click 1 for replace drum.. close cover.. Let me know if it works
Posted on Dec 05, 2010
Paper jam 2, check inside
You should troubleshoot jamming error message by removing toner cartrige, check if the little plastic sensors on the paper path are not stuck somehow, reinsert toner,close door, open back door check if the fuser sensor is ok ( and not broken), clean the papertray roller, restart printer and it should work. If that doesnt fix your problem it can be a faulty sensor or some tiny paper left somewhere you can't see and sensor detects .. Hope it helps.
Apr 07, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Samsung scx3405f compatible toner
hello . i have a samsung scx-3405f and i have been refil the cartrige ... after i refiled my multifunction machine say on the display "Not Compatible toner cartrige". i donn`t know what to do to him because i have buy a new cartrige and she tell me the same thing. please answer to filedoc2008@yahoo.com ... tks verry mutch
Feb 05, 2013 | Samsung SCX 3405FW - Multifunction fax /...
Replace/Install toner waste bin error message of samsung clp315
The toner box is probably full. The toner box is a clear box on the left side when you open the front cover. The box has the labels Y, M, C, and K on it. Pull it out using the tab at the bottom. find a place to empty it. You can do this by turning it upside down and gently tapping it. If the box is full some toner may be outside of the box causing the sensor to be blocked even after it is empty. You may want to clean the box, toner cartriges and inside the cavity with qtip, tissue paper (without lotion), or air.
Oct 21, 2010 | Samsung CLP 315 Laser Printer
Re canon d320 error E100
Beside you ended the limit of cheeping cartrige in 3500 copees format A4 mineses, you should not simply fuel his(its) toner, but gain new one cartrige or reenter the cheep microcircuit whereupon fall asleep toner
Aug 02, 2009 | Canon Office Equipment & Supplies
Fairly new toner and display reads "Install black cardtricge"
I have just resolved the "Install black cartrige" issue on my printer I am not sure if it will solve everyone's problem but these are the steps I took to solve the problem.
1. removed the black cartrige.
2. removed all the paper from the tray and noticed that one of the pages was a little jammed.
3. I then turned the printer on and off again and still encountered the "Install black cartrige" error message.
4. I then put the black cartrige back in the the printer and restarted the printer.
5. When the printer restarted it started to initialize correctly and I perform some test prints to confirm that it was back up and running.
Apr 07, 2009 | HP LaserJet M1522nf Multifunction Printer...
Infoprint 1120 929 service toner sensor error code
Jun 09, 2008 | IBM Infoprint 1120 Laser Printer
Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 17, 2007 | Ricoh CL3000E Laser Printer
Ricoh CL3000 Laser, replace waste toner displar unit will not print, waste toner cartrige is empty.printer will not print? How do I reset unit?
OKI KIT-C3530N MFP LASER CLR P/S/C/F USB ENET 1200X600 128MB Printer Logo
1,339 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
