Home | Canon | PowerShot A310 Digital Camera | Does not see image, whe...
Canon PowerShot A310 Digital Camera
Problem for Canon PowerShot A310 Digital Camera
Does not see image, when lens cover is open.
By mondongo on Mar 25, 2006
Comments:
Mar 25, 2006
- No LCd imges are displayed.
Same Problem
Aug 12, 2008
-   I have Coolpix 995, the shutter doesn't open and I can not take any picture. Please respond to my query. -   salim110
May 12, 2008
-   I have the same problem with Panasonic Lumix LZ2. There is no connection with low batteries. Probably your camera has got hitted somehow and now the iris inside the lens doesn't open.
My question is: is this iris changeable without changing lens? how does this thing look like?
-   Olx7
Mar 24, 2008
-   I am having the exact same problem. What is the problem? What is the expense? Thx.-   Cooter-soup
Mar 13, 2008
-   When I turn Powershot S500 on with lens open, no image is previewed in LCD display (just recharged battery when this happened, have taken battery out and replaced several times) - I can however view images once taken. So display works obviously, just not the image preview anymore.-   Guest
Mar 07, 2008
-   I have the same problem with my PowerShot A640, and tried cleaning the battery contacts with a pencil eraser. Still no luck. When I press the shutter button, it sounds as though some lens hardware is trying to move. Is there anything I can do without taking it to a repair shop?-   norajb
Solution #1
posted on Mar 26, 2006
Somewhat Helpful)
hendrix
Rank: Wiz
Rating: 77%, 742 votes
I assume you tryed replacing batteries and all. do you tend to leave the batteries inside the camera for long periods after using it? Clean the inside of the battery compartment contacts with a pencil eraser. If you left the batteries in you likely have contacts that have corroded. Don't push too hard with the pencil eraser but clean them thoroughly.
in case this isn't the issue, chances are something there has gone bad. if warrenty is still viable, use it.
Was this helpful?
Yes
No
Solution #2
posted on Aug 30, 2007
Not Rated)
vinod kudale
Rank: Apprentice
Rating: 0%, 0 votes
I am having ls755 digital camera model it is giving trouble while getting on lens is is getting stuck inbetween is not comming totaly out batery is also full charged but some times if we on the camera frequiently some times lence come out and camera works please give me the solution my E-mail ID:-application6@mazakindia.com
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot A310 Digital
Questions and Unsolved Problems for Canon PowerShot A310 Digital
Do you recommend Canon PowerShot A310 Digital Camera?
Answer
Answer
lcd view screen flickers bad when camera is turned on but when I take the picture it turns out... (More)
Answer
Hi My Canon A310 is not taking photos. Battery ok. Flash ok. Mem card ok. Have downloaded all... (More)
Answer
I purchases a cannon camera a couple of years ago and have since lost the download software. ... (More)
Answer
Hi, my camera worked fine, until recently. I go to plug it in and it says error messages.No camera... (More)
7 Other Users Have The Same Problem - Continued
Comment by JenniLeigh, posted on Nov 10, 2007
When I turn my camera on to take a picture, the lens will open, but the screen is black. And even if i take a picture anyway, then go to view it, it is still black. But i can still view pictures taken from the past. how can i fix this?
Comment by Guest, posted on Nov 06, 2007
as i open the lens to take picture , the lcd seems to to be black no image was seen on the lcd, however if you are going to review all the past pictures stored you can view them
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PowerShot A310 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
