Question about Xerox Phaser 8200 Laser Printer
Phaser 8200 Help
Greetings and Thank you for your willingness to help.
I am getting two error code on my 8200, 15 004 45 and 07 005 47.
I beleive the first one is the heating drum and the second on is the clutch.
Do you have easy to follow instructions you could email me on how to replace these items. (I have already paid for repairs ($800) in the past at outragous prices. If I cannot fix this myself then I tossing it out along with over $500 worth of ink) We primarily use the printer at church for color borchures and ad materies. The printer has about 11300 pages printed so far.
Thank You
My email dwilliams150@aol.com
    President:
  • 2,072 Answers
That clutch is very easy to replace.
You take off the left cover, looking from the front.
Once you have the clutch it will be easily seen. But its on the lower part of the frame toward the front.
You take off a clip, slip the new cluch on, plug it in and your ready.
The cautions, Make sure you get the "U" shaped part of the clutch stuck in the metal bracket, or the first time the clutch engages it will spin and break the wire, and you would need another clutch. That is a common problem part with that machine, the new clutches are a newer style.
Also make sure you route the clutch wire properly. Keep it out of gears. Another thing to look for is on your maintenance tray, there are 2 black tabs that stick out. One on each side. Maybe an inch long and a quarter inch high. Check the bottom of them for wear, They should be straight, not having any cuts in it.
'Let me know, that should ( the clutch) should resolve both codes and as I said its easy.
Oh yeah, to take off the cover, there is one torx screw on the top back of the cover and one on the upper front, inside the front cover. Once those 2 screws are removed, grasp the cover at the top in the middle and pull up and toward yourself.
Good luck.
Posted on Sep 10, 2008
Phaser 8200 error code
I think I had this error once. Could be your bulbs (one or both) are out or are on their way out. I had to replace mine. They are 150 watt halogen bulbs. When you open it up, do you see lights on the side peering in?
Jul 02, 2009 | Xerox Phaser 8200 Laser Printer
Xerox phaser error code is : 07.002.44:10318 what dose this mean
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
Memory error
Have you try to restart your printer?
you may want to read below link. might be useful to solve your problem..
Mar 17, 2009 | Xerox Phaser 8200 Laser Printer
Error 15 004 45 37888
From the service manual:
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850, 860, and 8200 have a pre-adjusted head.
In other words, you need to replace the drum heater.
Thanks and please take a moment to rate as fixya.
Mar 13, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 15,004.45:50425 error
There are 2 150 watt halogen lamps that heat the drum that are blown out. Thats your problem. If you want to try to replace them let me know.
Feb 23, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 Error code 15.004.45:30201
The drum heaters are bad. There are 2 ,,,, 150 watt halogen lamps that warm the drum. One or both of them are bad.
If you want the directions let me know.
Feb 19, 2009 | Xerox Phaser 8200 Laser Printer
Xerox phaser 8200 Won't warmup properly
Does it diaplay a fault code? It may take 20-30 minutes to display. I suspect if you leave it on long enough it will come up with a 15,004.xxx code.
I suspect you have bad drum heaters, but please leave it on for an extended period of time and see what fault code comes up.
Thanks.
Sep 30, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
139 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
