Question about Teac AG-D8900 Receiver
Echo when playing surround sound
I can only play the "pro-logic" or "3 way" to not get an echo. When I go with "theatre" or any other surround sound, I get an echo I cannot get out. I'm running this through my computer and a projector.
    Scholar:
  • 124 Answers
You want to adjust the "DELAY" setting on the receiver. The standard (default) delay setting is 20mS, which may need to be shortened if your speakers are well behind your listening position. In a proper setup, you should not detect a significant echo effect in surround programming (unless it is a purposely "echoey" scene). Also, make sure you don't have any of the "enhanced" DSP modes engaged -- some of these are quite echoey. if it has speaker set up, there should be a setting for distance. You might have it set close, so that by the time you hear the fronts, the rears should go. Try setting it farther each time until it sounds right. good luck
Posted on Mar 26, 2006
My ipod touch 2nd generation suddenly developed an echo or tunnel while playing. the words are clear but prefer the previous normal sound.
Find if there is reverb. Not sure where you are putting the IPOD into the unit. Turn off the effects for that channel. There is usually a control for each channel that controls the amount of the channel sent to effects in addition to the normal mix gain. It sounds like yours got turned up for the IPOD channel.
May 03, 2011 | Pyle pro Pwma930i Vhf Wireless Portable PA...
Have just installed a samsung home theatre HT C5900 have set up speakers according to manual, but when we play a dvd it sounds as though the talking is echoing a bit. It is not crisp and clear. Thank you
The echo could be caused by something called latency. On some systems you can adjust this. It allows you to increase or decrease the speed the sound comes through the speakers, based on how far from your ears they are placed.
Jan 23, 2011 | Samsung Audio Players & Recorders
I have altec lansing pro logic speakers from my
Check that your computer doesn't have a microphone (internal maybe) and that it's not switched on.
Cheers.
Jul 08, 2010 | Audio Players & Recorders
When i connected the 5.1 home theatre to the LCD tv, there is a lag between the sound from tv and stereo system (just like echo).
That is very common because of video processing delay. You have to listen with either TV speakers or surround sound; but not both. Some TVs have an audion delay adjustment for TV speaker sync.
Apr 19, 2010 | Televison & Video
Surround sound
your tv might have aux out on the back, I would use that first.
IF NOT, then you will need to use the cable box.  Insert the red and white plugs at the other end of  this cable into the AUDIO IN TV or cable box connectors on the
media center.
Be sure to match red to red and white to white.
3. Use your TV remote control to turn the TV speakers
down to minimum volume.
This prevents the echo effect of audio playing
through both the TV speakers and your 3•2•1®
system speakers.
Apr 09, 2009 | Bose Cinemate Digital Home Theater System...
If i connect mic some noise is coming to my laptops speakers even in head phone speakers..whether i use the mic or not.it also causing severe echo....anybody can help to fix it....?
yes you need to turn off Dolby pro logic surround from within the acer audio options lists it seems to clash with windows vista's audio settings.
Mar 19, 2009 | Computers & Internet
No surround sound through tv
May be you have to set the Pro-logic option soundfield, this will matrix a 5.1 surround sound effect, unless of course you are sending a Dolby Digital 5.1 audio signal from your TV broadcast into the Home theatre system, also have to check the TV audio output to send audio output to a Home theatre system in other than 2 channel stereo.
Feb 09, 2009 | Insignia NS-H2002 Theater System
System echos when dvd is in. When I mute the Bose sytem I can hear the TV sound without the echo.
The echo you hear is the audio delay between your TV speakers and Bose speakers. Muting (or lowering the volume) on the TV will eliminate the echo. Some TVs have a setting to turn of TV speakers entirely, allowing you to listen to your TVs audio strictly through your Bose system.
Dec 20, 2008 | Bose 3·2·1 II System
No sound from TV only when playing DVD
Check carefully the RCA conections or others.Sometimes this conections break inwards end cause this problems.Check also the lead and the Set up from surround sound.Verify if the TV has settings for this kind of operation. A strong hug !!!
Jan 16, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Teac AG-D8900 Receiver Logo
2,203 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
