Question about Sony PlayStation 2 (PS2) Console
Playstation 2 my playstation 2 browser menu keeps coming up and when i press browse it says can not read disc.
  • 4 Answers
You'll get this problem for a variety of reasons... anything from scratched up discs to defective DVD drive motor to defective/weak laser. Use DVD movie in another DVD player to see if it the disc works. 80% of the time it is not too scratchy if it works in a normal DVD player. If it works in a normal DVD player but not in the PS2 then you definitely have a DVD drive problem. If you get this problem for new discs that are in good condition then most likely the laser is week or defective. You can repair this by replacing the DVD drive or the laser with an known good one. If want to try to fix it yourself and you have access to another PS2, preferably one that did not fail with these same symptoms, I'd be willing to walk you through it.
Posted on Sep 13, 2008
Cant change language to english go to system configeration but dont have english and dont know what languages are coming up.
To change the language settings on a Playstation 2 console, proceed as follows:
1. If there is a game disc in the console, remove it and then power the unit on/off.
2. When the opening screen appears, choose the bottom option of the two. You will see the foreign text, then the time and date beneath it.
NOTE: If you do not see the date, scroll through the options until the date appears.
3. Press UP once to get to the language select option.
4. Press X to select this option, and then select the choice to the right (English) by pressing X.
5. All the text should change to English.
6. Return to the Time and Date Setup and verify or set your time zone.
7. Press CIRCLE to exit the configuration menu.
8. Insert the game disc and navigate to the Browser menu to select the game or browse the memory card.
NOTE: If the PS2 is currently in another language, then you need to figure out which language it is in so that you can look up the translation for ENGLISH. Once you have that figured out, it should be a matter of changing it back and calling it a day.
May 27, 2011 | Sony PlayStation 2 (PS2) Console
How can i change chinese language to english in ps2
May 03, 2011 | Sony PlayStation 2 (PS2) Console
It turns on but will no longer read discs.
You can also try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with
your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
If after trying the above options and it still does not solve the problem, then maybe the lens is weak and that's why it cannot read any disc.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck.
Mar 28, 2010 | Sony Playstation 3 (PS3) Console
Playstation 2 will not read the disc
try going to the version press the triangle button then go to the console then enter then turn on the diagnostic then put the disc then go to the browser then wait for the cd to pop.(DO NOT TURN OFF THE PS2 OTHERWISE THIS MIGHT NOT WORK.)
Jun 29, 2009 | Sony PlayStation 2 (PS2) Console
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
PS2 Slim Disc Reading Problem
Is the disc branny-new?
I'd check with who made the disc . Maybe they know about the issue or you may have gotten a faulty disc.
Aug 27, 2008 | Sony PlayStation 2 Slimline Console
Ps2
you say it wont turn back on but it has power.
is the light red ( stand by )
or do you have green and blue lights
Did it fall????
try cleaning the disk and the lens
you can also run the auto diagnosis..
HERE'S HOW
Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point. NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
the above is a copyright of the PS2 user guide
Dec 29, 2007 | Sony PlayStation 2 (PS2) Console
Playstaion 2
can you go into the browser ?
can you view your mem card?
You can try the auto-diagnosis. heres how
or try cleaning the lens and games
Dec 28, 2007 | Sony PlayStation 2 (PS2) Console
My PS2 is having a wierd problem.
It is either a dirty or mis-alligned laser. It's best seviced by a repair shop.
Dec 18, 2007 | Sony PlayStation 2 (PS2) Console
Disk format
1) Turn on machine
2) Open Tray
3) With tray still open hold the reset until the tray closes.
4) Tap the reset once.
if there is a format disc error, it says "Please insert a Playstation or Playstation 2 format disc." It is accompanied by a sound similar to the browser, but with a more tense noise. This is caused by a disc being so badly scratched that it completely fails to recognise the format, or if there is a problem with the laser. Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point.NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
Dec 15, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
