Question about HP DeskJet F380 All-In-One Printer
! Button Flashing
Tried to print on too thick of paper and had a jam. I got the paper out without breaking off, but the printer won't print now. The top on/off button with an "!" next to it is blinking an orange/red light. I have tried turning off my computer and printer and restarting it and that hasn't helped.
  • Anonymous Nov 29, 2008
    Help, I need to use my printer! I have tried turning it off and on, tried removing the cartridge etc.No luck.
    Master:
    Sergeant:
  • 462 Answers
Remove ur cartridge keep it out now turn of and turn on.. all this with a time gap of 2-3 min...
Posted on Sep 13, 2008
I am positive there is no paper jam with my printer (Z2420) but message of paper jam still appears and it won't let me clear it.
Sometimes a very small piece of paper can still be in the printer paper path after clearing a jam especially if the paper tears while removing the jam. The piece of paper may be too small to notice. Try blowing out the paper area with compressed air. Other causes could be the thickness of paper you are trying to print on, ie photo paper, thicker bond paper. Make sure the print settings match the paper thickness. I have a Lexmark laser printer, and I will get feed problems if the settings are not set for the correct paper type.
I hope this helps.
Alex
Feb 10, 2015 | Lexmark Z2420 USB 2.0/ 802.11g Wireless...
Trying to print on card stock paper and get a paper jam Is there a setting for printing on card stock paper?
Hi Fuller90
Read your issue.
1. Kindly check the thickness of the paper. If the thickness of the paper or the card is more then normal paper, you will experience the paper Jam on this printer model.
2. You can try this step..... Take the Power cable out from the printer.
3. Press and hold down the power button for 35 seconds.
4. Now release the button and then plugin the power cable.
5. Check your issue.
Aug 20, 2010 | HP PSC 1350 All-In-One Thermal Printer
Photo paper jam what thickness of photo paper should i use for a hp photosmart 8250 i keep getting jammed up and think the paper is to thick
Be sure and check the printing properties before printing. make sure that you specify the kind and thickness of the paper. This way the printer expects that thickness when printing. Sometimes, glossy paper makes the printer jam easily. Try putting around 25 regular paper on bottom of special paper and see if that helps.
Sep 13, 2009 | HP Office Equipment & Supplies
My Brother HL-2040 paper led light won't stop flashing, the paper's not jammed or anything, I just put in a new toner, too. I tried doing what someone else said about opening the cover and holding Go until...
Hi. The reasons listed in the manual that cause the LED to flash normally are:
Front cover is open
Close the front cover of the printer.
Back cover is open
Close the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 6-5.
If the printer does not start printing, press the Go button.
No paper fed manual feed slot
Put the paper in the manual feed slot. See Printing on plain paper, bond paper
or transparencies from the manual feed slot on page 1-10 or Printing on thick
paper, labels and envelopes from the manual feed slot on page 1-13.
Memory full
The printer memory is full and the printer cannot print full pages of a
document. See Solving print problems on page 6-15.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Drum Error
The corona wire needs to be cleaned. See Cleaning the corona wire on page 5-14.
If you check out page 6-5 it tells how to clear the paper jam from the rear of the machine! A point often missed.
Check out the website below if you don’t have a copy of the instruction manual =
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002089/US_Eur.pdf
If all else fails, try a reset of the printer Drum & Page counter:
  1. With printer tuned on.
  2. Press and hold the “internal button” behind front cover, until all LEDs illuminate.
  3. Make sure Drum light is off, then release and close front cover.
Hope some of this helps………..Please post a response back here and let us all know if it works?............Regards, Cornwellnet (UK)
Jul 12, 2009 | Brother HL-2040 Laser Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
Lexmark x2600 printer
Pull the tray out at the bottom of the printer. This is causing the printer to think it has a paper jam. It is simply the paper feed button.
Any other issues email me at derrickfoster3@gmail.com
Feb 21, 2009 | Lexmark X2600 InkJet Printer
Paper jam
I removed paper from jam, red light will not quit flashing, I turned
printer off and on again, but it will not print and red light will not
quit flashing, What can I do?
May 12, 2008 | Office Equipment & Supplies
Canon PIXMA MP160 showing paper jam, but none
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
good luck...
Feb 24, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Nov 22, 2007 | Samsung CLP 300 Laser Printer
'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
HP DeskJet F380 All-In-One Printer Logo
73 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
