Question about Canon imageRUNNER 8500 Copier
Toner banding down the sheets
Toner is banding down the sheet after a copies
  • allegratc Sep 19, 2008
    Its bandind on the front and back of the copies, it seems to start out ok but then starts to streak
  • Canon Expert
  • 1,326 Answers
Need more info.... Is it pitch line accross the page the whole page or banding on the front or back side of the copies or is it black streaks down the page?
Posted on Sep 10, 2008
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Please describe how to clean dirty edges on the paper from my KM2430DL printer.
Inside these machines is a rather large, black sheet that is known as the transfer belt. This belt acts to transfer the toner from the drum to the paper, Though if the outside edges of these sheet become worn or mucked up with excess toner, it will produce a copy with vertical bands of toner. In order to attempt to clean this belt, you must first shut the machine off, then open the from cover and locate the transfer belt (may need to remove the toner in order to make it visible,) then, with a damp cloth (water) gently wipe it along with the grain of the belt. Repeat this step until no residual toner appears on the transfer belt, then reconnect everything and print several test pages. If the problem does not reappear, then you are all set. However, if the dirty edges begin to come back, you will need to replace the transfer belt as the wear marks on it are trapping toner and not allowing it to be cleaned properly.
Please keep me informed on your progress and I will help the best I can.
David R.
Dec 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
Black line down left side of sheet, if i'm copying a page that is and i can't get rid of it no matter what i try i've changed the drum and the toner and still get a line down the whole sheet
If the received fax's are ok and there is no line; and you only get the line when you make a copy....I assume the people you send to are also getting the black line down the page,?? then the problem is in the optics...favorite is some kind of dirt, glue, or corrector fluid on the glass that the original passes over when you make the copy.
Aug 20, 2010 | Office Equipment & Supplies
Kyocera KM1820 spots on copy about one-half down horizonally. Do
Based on your discription it is the process unit. The toner cartridge wont cuase spots on this machine.
Feb 19, 2010 | Kyocera KM-F650 Plain Paper Laser Fax
Have a line accress the copied page. already cleaned the glass
The Reason in block of the scene or in develope block. Assign copying and stop the main switch off in that moment, when sheet is found in middle of the way. Open the device, when you take out the stuck paper in the same way and see on imprint on sheet of the scene if band exists, or on paper or on cylinder, that problem in block of the scene. Analyse the block and extract the perfected toner. Such can be, when perfected toner overfills the container. I think in this reason
Sep 22, 2009 | Office Equipment & Supplies
I just installed a new toner cartridge and now all my pages have a thick black line down the right side of every sheet.
the new cart mite be bad:(. Do you have a second cart? next cart placed in the machine properly? Look for a toner band on the drum?
Aug 13, 2009 | Brother IntelliFax-2820 Laser Fax
Line on the sheet when I copy.
Most likely the scanner glass is dirty. You may have a very small speck on th scanner glass under the document feeder. When this happens a line will apear down the page that has been scanned/copied.
Even if you cannot see anything on the "****" Glass clean it anyway and check it from different angels of light and this should do the trick
Jul 07, 2009 | HP LaserJet 3050 All-In-One Printer
My printer does not pick up the paper sheets from the paper tray.When I took paper sheet in to slot it works.
Well - I don't know if this will solve it (since there could be many causes) but it worked for me.
1 - Remove Paper Tray
2 - look at rubber rollers in printer undercarriage
3 - carefully remove "rubber bands" from roller
4 - turn rubber bands inside out and carefully return to rollers
5 - remove toner cartridge
6 - remove print drum assembly
7 - return printer drum assembly and toner cartridge
the roller trick helps the printer pick up paper
the toner/print drum trick helps reseat the inner workings of the printer correcting any misalignments that impede paper flow
Jun 09, 2009 | Lexmark E232 Laser Printer
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
Samsung CLP-510 Print Quality problem
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
I've also seen this sort of thing caused by a crusty build-up of toner on a wiiper blade on the Transfer Belt, and or Drum.
Dec 01, 2007 | Samsung CLP-510 Laser Printer
Canon imageRUNNER 8500 Copier Logo
203 people viewed this question
old marine
old marine
