Question about Maxtor Hard Drive
Memory loss I recently bought a maxtor basics external 500gb hd (aprox 2mths ago) it worked fine up to now when i plugged it in and turned on my laptop to clear some space from my internal drive.There was only 40 gig used on the maxtor and i was transfering another 35 gig when it was reported that there was not enough room to copy files.When i checked the maxtor it said that it was full 69 gig???? When tryed reformatting it would only format 70 gig not 500 . I am running a toshiba dual core with XP media centre edition
    Scholar:
  • 71 Answers
Check your warranty.  Try to get them to replace it.  WalMart will take anything back even if you didn't get it there.  Just tell them that you did.
That's happened to me before and there is no way to recover.  If there were files on there that you can't find use www.recuva.com  Other than that it's shot. Get a Western Digital MyBook.  Better reliability.
James Mac
Posted on Sep 09, 2008
  • 3 Answers
It seems to me that when the drive was partitioned, the whole thing was not partitioned. If using Windows XP you can go under the Control Panel, Administrative Tools, Computer Management and then Disk Management. You should be able to see the drive and if any unpartitioned space is available.
I dropped a short distance my maxtor 500Gb external HD
Open it up, and gently move the pickup arm, see if it got knocked out of place. When it is free, close it up and try again. If it is under warranty, send it back first.
Dec 01, 2013 | Maxtor Computers & Internet
I have a Maxtor OneTouch 4 Plus 500GB external harddrive...I originally used it on a really old dell desktop computer but since then recieved an HP pavilion laptop...the laptop has windows vista. At one...
1.) Right click My Computer
2.) Click on Manage
3.) Click on Disk Management at the left side panel of Computer Management
4.) Right Click on the USB device in the Disk Management panel
5.) Click on Change Drive Letter
6.) Assign an Alphabet from E-Z to the USB device
7.) Click Ok
Go to My Computer and find the drive letter that you have assigned.
Hope it helps.
Jun 02, 2017 | Maxtor OneTouch 4 Plus 500GB External USB...
Maxtor 3200 hard drive not working alongside Maxtor Basics
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Sep 21, 2009 | Maxtor Hard Drive
Open external drive maxtor basic 500GB
it may be like the one i have which is a maxtor basics 1.5tb drive. There is only one screw behind the sticker. The rest is clips. This is the guide i used when opening the case.
http://www.computer-aid.com.au/blog/2009/02/17/how-to-take-apart-a-maxtor-basics-external-35-usb-drive/
Mar 28, 2009 | Computers & Internet
Light turns on but My Computer does not recognize the drive
Sounds like you lost the drivers for your external. W/ out an online PC you cannot download them either. Do you have a friend that could do this on their PC? That is the only way.
Feb 16, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor Onetouch 500GB went dead
if there is warranty take it back to the shop you bought it from.
Dec 31, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
500GB BAsics External USB drive
Simple Solution, Install XP on the Vista Machine...
Aug 28, 2008 | Maxtor Hard Drive
Hard drive is not recognize by the computer
have you tried using it on another computer? if its a plug and play device and it works on another computer, the problem may be with your computer. you have to first try this device on another computer to see if it works or not.
Jun 11, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Maxtor Hard Drive Logo
169 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
