Question about Zenith Televison & Video
I have a zenith pvr5263dt projection television.when I turn it on the color is out of alignment, I go to the menu and in one section of setup cross hairs come up with the colors misaligned but it does not show you how to align them so they blend together as one instead of showing all three colors
  • mileyj Sep 10, 2008
    Thank you for your quick response Dan.
    Yes I would like to repair the problem, my major in high school was Radio and Television repair but that was a long time ago but I can still solder so if you will provide me with the detailed instructions I would greatly appreciate it.
    I will look into it tonite. I will get you the update once I correct it if it is correctable, thanks once more
  • 4,234 Answers
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Please let me know if you wish to do this and I'll provide more detailed instructions.
Dan
Posted on Sep 09, 2008
  • ABRsvcs Sep 10, 2008
    Ok. Open up the back and locate the convergence ICs. These are the large black on es attached to a heatsink. They should be marked STKxxx. Try resoldering the pins on these first. If that fails, replace them. If you need to replace them, check in the same area for low valued resistors and/or pico fuses that may have opened up as well.
    Keep me posted.
    Dan
Zenith rear projection tv, left 1/3 of screen has color shadowing like colors are not aligning...tried adjusting with setup menu, but didn't work
Projection sets have two very common problems listed below. bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Apr 26, 2011 | Zenith R57W46 57" Rear Projection...
Colours out off focus
There should be a section in your menu that says "convergence". Select that and use the arrow keys on the remote to align the colors with the white crosses. You will have to do it for each corner of the tv. Otherwise you may have to replace some boards inside of the unit, which can be expensive.
Feb 28, 2011 | Samsung HCN4226W 42" Rear Projection...
My Zenith tv has wild colors and double image. what do i do?
Possible that the lamps are out of alignment resulting in poor convergence of the image.
You might have tto use a test pattern to see if this can be corrected or if this is the fault if the convergence section.
Sep 17, 2010 | Zenith R56W36 56" Rear Projection...
My zenith big screen tv is out of focus and we cant find any master focus control. How do we fix the focus?
It is unusual for a rear projection to be out of focus since the projectors are fixed. But, it is common for the projectors to be out of alignment, in which case the picture will look like a bad 3D movie of yesteryear.
Go to the setup options / menu, look for the ALIGN option, follow instructions on screen.
Jun 13, 2010 | Zenith R60V26 60" Rear Projection...
Red green lines across my screen on 51 inch tv hdtv
If you cannot align those crosses, then the convergence section is damaged. should be repaired by a qualified technician, its a big job.
Jul 20, 2009 | Philips 51PW9363 51" Rear Projection...
My big screen Rear Projection Television set is blurry.
Consider new purchase, your crts are getting old and can't reproduce same quality. High voltage is going and loosing focus. good luck
May 17, 2009 | Zenith R57W46 57" Rear Projection...
Cannot reset vertical convergance
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Toshiba Rear Projection Tv 40WH08B
If the convergence on one or more color does not align using the convergence setup procedure, that means that one or more convergence ICs must be replaced, that is the reason why you get bad picture.
That means that the convergence ICs are bad and must be replaced, the job is about $200/$300.
Here there is an example of the repair needed: Fixing Convergence problems in RPTV's
Mar 10, 2009 | Toshiba 57H81 57" Rear Projection...
1995 zenath 50 in. projection tv(need help to align w/remote
It appears that you can get a wealth of info on your Zenith here:
Zenith info
Mar 04, 2009 | Zenith IQB50M90W 50" Rear Projection...
My colors all of a sudden went out of wack
Is there an advanced convergence setup anywhere in the menu where the screen displays a grid? If so, you might want to get into that and move along the grid to each section that looks off. Adjust until the color falls behind the gridline, and move on to the next. It can be a time-consuming process, but should take care of your convergence issues.
Jan 20, 2009 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
228 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
