Question about Viking Kitchen Ranges
Elements not working, have power on both legs of 220. Have replace the elements. Lights and fans work. No heat.
  • Wkmmarfa Sep 10, 2008
    I intending to indicate that both legs of the 220 at the box was live and that the breakers didn't trip. I have a new lower element. Have power to the light, fans but none to the elements. Its still possible, of course, that there is a loss in the neutral. The other problem is that this is a built in oven and I cannot. Its difficult to get to the wiring without pulling the whole oven. Being alone this is almost impossible. Oven is kinda heavy.
    Would appreciate any other suggestions. All is appreciated.
    Kerr
  • Wkmmarfa Sep 11, 2008
    Yes, I know I will have to pull the oven. Not happy about that thought. Its too heavy for one person. However. I have not looks to see if I have an open circuit on the stat. Selector could be faulty. I will have to pull unit to determine if connection box is ok and not burnt.
    Thank you for the suggestions. Everyone helps. I am thinking about pulling a couple of the circuit boards and replacing them. There are a total of 4. It would not be a big chore except for pulling the oven.
    Many thanks.
You are faced with taking the oven out whatever.
things to look for are
stat not open circuit
selector switch not faulty
is there an overheat stat that has tripped
is connection box on the oven ok and not burnt
Posted on Sep 11, 2008
    President:
  • 1,462 Answers
I think you maen that you are seeing 220v on both terminals of the element and this would mean straight away that the element is ok
the problem is that neutral is not present
take care doing this.
remove wires from both sides of element. check which wire is live and the other should be neutral. trace the neutral wire and see if you can find a break or disconnection. one possibility is that neutral is routed via an overheat stat and this has gone open circuit
Posted on Sep 10, 2008
I AM GETTING ELECTRICITY TO THE 220 PLUG AND THROUGH THE 220 PLUG WIRE TO THE STOVE JUNCTION BOX. THE STOVE TOP AND OVEN HEATING ELEMENTS ARE NOT HEATING UP BUT THE INDICATOR LIGHTS FOR BOTH ELEMENTS SHOW...
The indicator lights operate on 120 volts whereas the elements operate on 220 volts.
Using an electrical test meter go between the two hot legs and see if you are getting 220 volts. If not you have an open or non completed circuit.
Do not test from one leg to ground as you will probably read 120 volts for each leg. By reading across both legs you should get 220 volts.
May 03, 2011 | Microwave Ovens
Runs fine no heat
if its a 220 electric dryer, check both legs of power coming into it. power only to one side of the plug will cause this problem. check the power at the breaker if plug doesnt have 220. breakers do go bad.. if the dryer is older than it could be that the motor is running to slow and letting the heating elements get to warm and kicking out the bimetal relays. the relays will only do this for so many times and then they will stop working . if you have the dryer apart ,the relays are round and usually have just 2 wires going to them. held in with two screws. if you ohm this out it should have resistance ,if none than its no good. could also be heating elements themselves.. you can usually just check them for continuity...
Dec 09, 2010 | Dryers
Rheem 40gal. electric: have 220 power at both elements at the same time but only one drawing is correct?
A 220 volt circuit does not require a neutral, so both 110v legs go to each element. The elements draw from each of these 100v legs. Are you having any problems with it heating sufficiently?
Dec 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Can I test dryer timer to see if its any good?
I do not think a "NO HEAT" problem can be caused by the timer.
Sounds like another electrical problem:
Have you check the house breaker or wall receptacle to see if you are feeding 220V to your dryer?
Have you check your hi-limit thermostat to see if it has continuity?
Those are the most common causes of "NO HEAT"
Aug 17, 2009 | Whirlpool LER4634J Electric Dryer
GE range - oven stopped working after cleaning
If you bent the bottom element out list out of the way, you may have broken the actual heating element inside of the metal sheath. Or, it could have shorted to ground.
After tinkering with it more, you might have caused another short, and now both legs of 220 VAC have either a blown fuse or tripped breaker.
Reply what you find is the sondition, and I will help you troubleshoot more.
Jan 24, 2009 | Kitchen Ranges
Heat coils in central air conditioning unit look fine under examination, checked with an ohmmeter both coils showed continuity. Power at both coils indicated 110 volts. Unit fan runs fine but there is no...
Are you getting 120 vac or 220 vac at the unit? Check the voltage at the first terminals inside the unit as well as the breaker. You should have 220 vac at the elements and you are dropping a leg some where.
Jan 17, 2009 | Heating & Cooling
JENN AIR WALL OVEN ELECTRIC
Are you sure the breaker didn't trip on one side? If one leg of the 220 is out, the lights and controls will appear to work, but the elements will not heat up. Make sure you have 220 to the appliance. It's also possible that you pulled a wire off somehow when changing the broil element.
Dec 12, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
New Heating Element; Has Power But Not Heating Up
Let's go over a few things:
  • Your unit uses 220 volts to provide heating.  Some elements are wired to one of the two 'legs' of the 220 giving you 'low'.  High uses 220
220 consists of three wires...two 'hot' (red and black) and a neutral which is white.  Neutral to hot will give you 110...hot to hot 220.  Measure accordingly and use care!  Neutral and the frame of the stove are effectively the same terminal...for safety.
  • You say some of the wires are burnt or a fuse is blown.  They need to be replaced with proper wire...not just any kind.  There is high temp insulated wire available from many ACE and other home stores or parts shops.  It needs to be thick enough, too.  Make all connections carefully and fully onto clean terminals.  Tighten clockwise.
  • Check the voltage coming to the element on various settings as above.  If you only get 110/120, you have an open supply issue which needs to be found.
Look for: loose wires, corrosion, burned insulation to ground.
Nov 19, 2008 | Belling CookCenter 151 Dual Fuel (Electric...
Kitchen Ranges Logo
140 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
