Question about JBL LC-S960 Car Speaker
Speaker installment sorry, wasnt very descriptive before... i do have 300watt amp with two subs wired into it and thats all working also the standard car speakers sound good enough but i have a pair of 6x9's i put in parcel shelf already and i wanna wire them in. my brother could do it in seconds cos a) its all his old stuff b) he has done it 100 times before for pretty much everyone but he cba with me :| so...i have 4m of speaker cable and the spade parts to connect to the 6x9s but im unsure whether the wiring from the speakers should run to the existing speakers or the head unit i read on this site that i need to connect the left speaker to purple/black and all that cant find page again and i wrote down but left in car and i cba to get it... but i understood that and if this is correct in my case i wanted to know how to switch the wires also if u could...not entirely sure what crimping and splicing is :S cheerz
  • jackoby1991 Sep 09, 2008
    Rear Left
    green + to Big Spade on speaker
    green/black - to Small Spade on speaker
    Rear Right
    purple + to Big Spade on speaker
    purple/black - to Small Spade on speaker
    Thats what i was talking about a second ago :P
    might help ?
    Scholar:
  • 71 Answers
I would run a 250-500 watt 2 channel high input capable amp.  run the original wires to the orginal speakers and jump off the original wires to the amp to push the secondary 6X9's you have.  So my understanding is.  you want the 4 original speakers and subs and add 2 additional speakers making 6 speakers not uncluding subs..
Head units care barely push 4 decent normal size speaker.  Usually they are 30-55watt per channel.  If you have 2 non sub speakers that are 250 watt max.. that's 500 total but don't push the amp all the way...start with it at 1/4 and listen to your stereo at a higher than nominal volume slowly turning up the amp.
James Mac
Posted on Sep 09, 2008
  • James Mac
    James Mac Sep 09, 2008
    also...your spade connectors are attatched to the wires by crimping..need a crimp tool.  Splicing is just twisting wires together held by tape or wire nut.  at least use a wire nut.
    Crimper kits - like this
    James Mac
I have two 12 inch Kicker subs and a 1500 watt Boss amp. i took them to a car shop to see if they work and the guys said the wiring inside the box had to be replaced. they thought that the negative wasnt...
there are only 2 wires going to each speaker inside the box, one of them will have a stripe on it, make sure that the stripe wire is on the positive terminal of each speaker,
Oct 08, 2013 | Kicker Car Audio & Video
How to wire a 2400w amp to 3 12s subs
if the amp is a 2 channel, u could either bridge them all, or if you wanted to, you could hook 2 speakers to the two seperate channels, and then hook the other one to the negative on one channel and the possitive on the other. if this wasnt what you meant, just, try to tell me more about the amp... thanks
Dec 05, 2009 | Kicker CVR10 Car Subwoofer
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
Have a 300watt amp on some kicker subs is there anyway to get more power or do i need a second amp
No way unless you are able to bridge the amp. Check the gain level too, you can turn it up but woudn't recommend more then 3/4 of the way.
Sep 10, 2009 | Alpine SWR-1240 Car Speaker
Popping sound! please help - jl 500/1 and two jl w3v3 2ohm subs
no connection are good + to + -to - thats all that matters. either the speakers are blown or you need a stronger amp. since you already tried speakers probably need bigger amp. definitley not the box. no such thing as a break in period, are the subs 10 12 inch or what. you could try to bridge them too that means hook both up to the same +-terminals, 2 wires per screw. it usually isnt the way they hook them up, its the wires fuses etc that cause problems. what guage wires is the speaker wire, the power line etc. if you give me these guages i might be able to get somewere
Feb 24, 2009 | Jl Audio 12W3 Car Subwoofer
Audio system set up
Well one problem is you might need a smaller amp depending on how many speakers you have, 1200 watts is way overpowering for 300watt max speakers and could possibly blow them and even catch them on fire!!!! But everything else is compatable because all of your epuipment is of a newer products but if you dont have 4 guage wires or anything else make sure you get them heres a list: 4 gauge wires for power and ground, REM wire "blue is the normal color" RCA jacks, A compacitor, fuse for battery to amp to keep system from blowing up, 8 gauge speaker wire or even 12 guage to hook up from the amp to the speakers, That should be the common things you need to have a good thumpin system!!!!
Sep 12, 2008 | Performance Teknique ICBM-892 Car Audio...
A300HLX Amp + 600 Watt JL Audio Sub
Ill go for a better GROUND , sounds like its not grounded properly and thats why the RED LIGHT . DO A RE CHECK on the installation . hope this helps
Apr 29, 2008 | Jensen A300HLX Car Audio Amplifier
Jensen Amp and Sub
If you followed the instructions correctly, then the amp must be defective. This is sort of simple.
My generic suggestions:
You have the power, the ground, the outputs to the speakers, and then the input.
Make sure that none of the speaker wires are somehow being grounded. Make sure that nothing is shorted that feeds the speakers.
Jerry G.
Apr 27, 2008 | Jensen A300HLX Car Audio Amplifier
JBL LC-S960 Car Speaker Logo
101 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
