What does E2 mean when it appears on my PC720 Panasonic copier?
This is the first problem I've had with my PC720 copier.  When I turn it on the #10 and E2 flash and nothing works.  The first time I attempted to use it I heard a whilring sound...that soon stopped and now only the two  flashing #10 and E2.  No paper stuck.  Any idea what's wrong?
  • 1,326 Answers
A E210 has to do with the scanner part of the copier. Is the lens moving OK on warm-up? Dose it move at all and what about the optic's do they move at all? I would need some more info on the problem.... I don't want to lead you on, that it is a easy fix... It is a fairly older copier.. It may not be worth repairing
Posted on Sep 10, 2008
Copier is Canon PC 720 Copier turns on, but makes
You said you unplugged your copier, did you unplug it for 10 to 15 minutes before plugging it back in, plug it into a differed
outlet that you know works and plug it directly into a wall outlet instead of a power strip. Check to see if your copier reaches stand-by mode then make a test sheet.
If this does not work then you have probably have an internal processing component which requires attention.
Apr 02, 2017 | Koutech Systems PC720 (IO-PC720) (IOPC720)...
Whenever I try to print a page, error E2 appears, even reinstalling does'nt solve the problemm
E2, Error Code [1000] or Alarm LED blinking in 2 times is mean No Paper in Auto Sheet Feeder. Insert paper in ASF and press OK button.
May 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Thre is a little wrench on the left side of the screen. What do I do?
if there is an error message along with it eg. E3-10 or E2-02, recycle power, that may reset device. if not it means a service error has occured and need a technician.
Mar 17, 2010 | Panasonic Workio DP-3030 Printer
I need a technical manual for a Canon Copier PC720
Scroll Down put in the 4 digit code, click download
http://www.devicemanuals.com/guide/Copier/Canon/Canon-Personal-Copier-PC720-User-Guide-TkRBNU9UYz.html
Oct 20, 2009 | Canon PC150 Personal Copier (PC 150,...
Turn on copier and get noise then E2 10. Can You
E2 Scan problem
Check motion scanning device. Check the position a sensor on carriage, they controlled, and are fixed by bolt. Can fixatives on lid have from below lost its fastening
Oct 10, 2009 | Office Equipment & Supplies
What does code U16 mean on Panasonic fp7713?
Did you replace the Developer unit?
I beleive the Developer unit is not installed properly
Jan 26, 2009 | Panasonic FP-7735 Black and White Copier
On a Ricoh FT 4415 copier, what does error ''E2'' mean?
Hello,Check out this site and see if any of these error codes can help you: http://www.copier-help.com/copier-help/
Have you checked the power fuse? Or have you looked at the incoming power circuit board. Could there be any burnt resistors, blown capacitors, or bad voltage transformers?
Check things out because many times when a machine doesn't even power on (no lights, no life) - it's usually a sign of something blown - fuses, circuit board, lamps, etc. Hope this helps.
Dec 11, 2008 | Office Equipment & Supplies
Canon copier PC720
A E2 code deals with the scanner. The optics of the copier. Has itbeen moved resently? Your lens may be off it's track. Turn the copier off and remove the copy board glass and the Black Box and try to move the lens and the scanning mirrors to see if they can move smoothly. If not you have found your cause of the noise and what needs to be repaired. It may not be worth getting fixed. That is older model, it's up to you..
Jul 25, 2008 | Office Equipment & Supplies
Canon PC720 copier
Looking at the copier where the paper comes out of, there is a switch to open and close it. Pull up and look on the left side in the back. There is a little spring that comes off, or breaks, or the plastic that holds it on breaks. THIS CAN PAPER JAM THE MACHINE AND SEEM LIKE A MAJOR PROBLEM. ALL IT IS IS A LITTLE SPRING. Hope that is only your problem.
Dec 31, 2007 | Koutech Systems PC720 (IO-PC720) (IOPC720)...
106 people viewed this question
jasbo
jasbo
