Home | Sony | Cyber-Shot DSC-F505V Digital Camera | Replace flash
Sony Cyber-Shot DSC-F505V Digital Camera
Problem for Sony Cyber-Shot DSC-F505V Digital Camera
Replace flash
By Yogbo on Mar 24, 2006
my flash does'nt work. how do you replace the bulb?
Same Problem
Feb 05, 2009
-   The flash on my Canon A620 started flashing overly bright for the first flash, then fine for the ones following. And it also refuses to flash. I changed the batteries, no change, put the original batteries back in, the camera flash started working again (after the first overexposure flash).
Where do I take the camera for a flash repair? Or would it make more sense to just get a new camera?
-   gategrrl2003
Sep 14, 2008
-   I've got a Samsung Digimax 530 thats worked we'll since I bought it in 2004 and now - no flash (Well about 2% of the time it will flash) I've had this camera long enough I know it inside an out- Its not a setting. -   talisyn
Jun 29, 2008
-   Flash does not work on our Sony Cybershot DSCP52 camera.-   Guest
Feb 26, 2008
-   Dont have a solution for my problem my flash does not work either. My Camera is a Nicon Coolpix L1. I have turned on the Lightening symbol and nothing happens have any ideas...?-   Hambo1935
Feb 18, 2008
-   I have a canon power shot g3 and my flash too has stop working. What should I do?-   Guest
Solution #1
posted on Apr 03, 2006
Somewhat Helpful)
BowerR64
Rank: Wiz
Rating: 80%, 973 votes
Usualy the flash is soldered into the unit. Are you sure its on? some pop up and some have to beflipped up automaticly. Does your display show a lighting bolt? the normal icon for flash being on is a lightning bolt. If it has a line threw it it is disabled in the settings somewhere. Ive never seen one that has failed so it makes me think there is a wrong setting somewhere. Try and hold it up maybe there is dust or dirt o the switch keeping it from detecting it is up and ready for use?
Was this helpful?
Yes
No
Solution #2
posted on Nov 11, 2008
Not Rated)
do o little
Rank: Apprentice
Rating: 0%, 0 votes
i have a nikon coolpix. i've tried every flash option yet the flash never goes off....
i took it to a repair shop and he said i'll need a new flash circuit and it's going to cost
$130 to replace it. i don't know much about cameras, but is this high? also, would it
be better to just get a new digital?
Was this helpful?
Yes
No
Popular Solutions for Sony Cyber-Shot DSC-F505V
Questions and Unsolved Problems for Sony Cyber-Shot DSC-F505V
Do you recommend Sony Cyber-Shot DSC-F505V Digital Camera?
Answer
Answer
What is wrong with my Sony digital camera if it is turned on and then goes off and it is... (More)
Answer
My memory stik burned and I can' t find an 64 megabite memory stic for my Sony Cyber-Shot DSC-F505V... (More)
Answer
My Sony DSC-F505V's LCD screen turns off by itself often.  Sometimes it goes on again but... (More)
Answer
Hi there My sony dsc F505V screen is functioning but the picture is blank and white. What must i... (More)
10 Other Users Have The Same Problem - Continued
Comment by glideride, posted on Dec 02, 2007
flash quite working everything acts like it is going to work but dont flash was takeing flash pic,s when it quite
Comment by Insanenyyfan, posted on Nov 28, 2007
my flash is not working and i would like instructions on how to fix it. My camera is a Kodak EasyShare C643
Comment by Guest, posted on Nov 17, 2007
No flash for me either its a vivitar vivicam 55
Comment by notflashsavy, posted on Nov 16, 2007
my flash does not work on my camera fuji f-470 you can see it try to flash if you hold your hand over it to see and i have tried every setting to fix it. please help?
Comment by Ugenius, posted on Nov 07, 2007
I have a Sony DSC-W1 camera. The flash stopped working recently. There is no error code, and all the flash symbols can be set as normal. The flash does not fire in any mode.
The voltage on the xenon tube and the 2 capacitors are about 240 volt which is normal .
I replaced the xenon lamp but the problem persists. Should i perhaps change the reflector as it is part of the triggering ?
My name is Eugene and my e mail address is eugenevann@googlemail.com
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Cyber-Shot DSC-F505V...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 721
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
