Question about Maytag MER6772 Gemini Electric Kitchen Range
Bake element doesnt work everything else does
Hello, The bake setting stopped working the other day. I opened oven to see that bake element was melted mostly on right (if looking into oven) 2/3 of unit. I replaced with new element. It still is not working. I measured resistance of new element; it is 16.8 ohms. I opened up the back of oven to expose wiring, everything looks good; no burned wires, no wires appear disconnected. We are having relatives over this weekend so I am in big trouble with the wife if I dont get it fixed. Any help is super appreciated. I had the same problem on a Maytag Gemini Model MER6770ACW. The lower bake element blew up (shorted and melted). Replaced it with a new element from Maytag. The element does not work. No electricity at the element's terminals when the oven is turned on. The best advise I got so far is that the control panel is damaged from the voltage surge. (Replacement cost is about $300)
  • 1 more comment
  • dmiller58 Sep 10, 2008
    I have the exact same problem. The broil element works but when I am trying to preheat, the power cycles on and off. and there is no power to the baking element
  • colacho Sep 24, 2008
    I was making bread the other nite and suddenly the bake element or the bake coil exploded, it sound and it had a lite flame going on and the setting showed that it was on and the baking was interrupted and we ended up with non cooked . The stove is less than 2 years old. I am very dissapointed because the stove is not cheap.
  • kbiro Sep 27, 2008
    Correct me if I am wrong but I thought that the bake element would melt for only one reason: the inside conductor (the heating wire) shorts to the element casing, the metal tube, that ends up melting.
  • 409 Answers
the bake element can melt for various reasons, however, i think that you problem lies somewhere else.
here is the service manual. have a look through it and let me know if i can be of more help.
Posted on Sep 26, 2008
  • Carmen Mikulic Sep 28, 2008
    hi there,
    you are partially correct.
    quite a few of my customers have had expriences where, all they did was run a self clean and the element could not withstand the heat. also, many of them just cleaned the oven the regular way (manually) and when they went to use the oven again, the element just burnt and stopped working.
    in your case, would definitely check the switch or recepticle behind the element for any shorts.
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 | Ovens
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
nuker100.jpg Use an old tooth brush to help clean off the grille area.
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Q - My microwave went dead when I opened the door ( same problem as closed the door ).
A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q - My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Q - I burnt something in my microwave and now it is!
A - The fuse inside the microwave may have blown, but more commonly the flame/oven thermostat has sensed the over cooked food and the flame/oven/cavity thermostat has opened up - Info on that
Sep 09, 2008 | Maytag MER5775Q Electric Kitchen Range
Frigidaire oven fefl68 broil element comes on on broil only will not come on on bake or clean
Hello - - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Nov 17, 2012 | Ovens
Why has both top elements stop working at the same time
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Sep 25, 2012 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery oven large element stopped working
Hello -
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven elements just stopped working
If I understand your use correctly, you were using the oven to heat the space? Or for baking?
Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
Jan 23, 2009 | Ovens
Err on display when I try to set the bake temperature
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
Frigidaire oven not working in bake setting
Hi Thanks For The Question. I Would Check The Bake Element. Replace The Bake Element .Thanks The Appliance Doc
Oct 06, 2008 | Frigidaire FEF366 Electric Kitchen Range
Control unit is probably the problem, You should check your Breaker to make sure it didnt trip outside of that you can check voltage to the element with the oven set to bake, if you dont have votage to element then it would most likely be the board. I just checked the wiring diagram for this unit and there is an over limit switch which is a long shot but worth checking. My bet is on the board. There are 2 listings for the part number so if you check on parts make sure you have full model # serial # AND series #(should be a 2 digit number like 10 or something)
Mar 20, 2008 | Maytag MER5775Q Electric Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
458 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
