Question about Dishwashers
My Ariston LS 601 - K LS 61 S dishwasher is not completing its cycle. It is heating up but gets stuck during the cycle. Any ideas?
  • 883 Answers
SOURCE: my dishwasher trips out on certain cycles
sounds like faulty wiring inside unit. your circuit breaker is detecting an overload current condition...must look inside for wire touching frame. if none found, then wire fault may be inside of a device like motor or solenoid, so check these with ohmeter to ground-each wire (except chassis gnd) must be isolated from ground.
Posted on Jun 05, 2007
  • 209 Answers
SOURCE: Water doesn't drain
simple one this, just clear out the waste pipe and the inside food filter and the outlet pump, also check the outlet where the pipe goes (under the sink?) its a simple blockage somewhere, if i have helped rate me, and work safe remove the plug etc
Posted on Sep 16, 2007
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Posted on Jan 10, 2008
SOURCE: Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Posted on Apr 26, 2010
SOURCE: need to find parts dealer for Ariston dishwasher
Please let me know where I can order replacement part for LI 700-NA I need a water valve, serial number of that part 409245172. Thank you
Posted on Oct 14, 2010
Kenmore ultra wash dishwasher gets stuck at 42 on the control panel
Be aware that all (well, almost all) dishwashers have a "thermal hold" period in their cycles. This is the point in the main wash cycle where the heater is turned on to heat the water to the optimum wash temperature (about 150 to 160 deg F), and during this time, the timer will stop advancing. Once the water has reached the desired temperature, the cycle will continue. IF it does not, then you have a water heating problem. This could be caused by a bad heating element, a bad controller, a bad thermostat or temperature sensor.
Mar 20, 2015 | Kenmore Dishwashers
Ariston dishwasher LS609 the cycle nob does not
Had the same problem with my 12 year old LS609. The cycle knob sits on top of what Ariston calls the control board. This control board is most likely to be your problem. It was in my case.
May 14, 2010 | Ariston Technologies LL64WNA Built-in...
Apr 26, 2010 | Ariston Technologies Dishwashers
The detergent dispenser on my Ariston AS100 Dishwasher will not open automatically any solutions please
put unit on a quick wash as the dispenser opens early in the cycle .. if it heats and the dispenser is still closed then a new dispenser is in order...
Nov 25, 2009 | Ariston Technologies L63 Free-Standing...
Detergent cube does not disolve
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Nov 12, 2009 | Ariston Technologies L63 Free-Standing...
Kenore Elite Dishwasher
Either:
Good luck,
Vlad
Sep 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
My Ariston LI 700 I dishwasher doesn't complete wash cycle
dear customer,
 we recommend u to perform the following checks on ur dishwasher,
  1. Test the timer motor
  2. Test the thermostat
  3. Test the heating element
for more details for self test instructions try the link http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Plz rate this solution.. thank you..
Apr 08, 2009 | Dishwashers
Does not dry all the way
I too have a similar problem. Drying light blinks, doesn't shut off, little if any steam escapes when door is open during drying cycle. Wonder if this is Ariston's Dynamic Drying? My unit is new too.
Aug 20, 2008 | Ariston Technologies LL64WNA Built-in...
My dishwasher trips out on certain cycles
Jun 05, 2007 | Ariston Technologies L63SNA Stainless...
Dishwashers Logo
652 people viewed this question
Top Dishwashers Experts
Owen Barnes
