Question about Whirlpool GHW9400 Front Load Washer
120 volts 50 hz
I am using the washing machine, but it does not complete all of the cycles, once it gets to the rinse/spin (and the timer shows 1 minute left,) it stays there and never changes to the last cycle of drain/spin. I suspect that has something to do with the different electricity cycle as the washer in question is plugged in a line that while is 120 volts, it is 50Hz (is being used overseas.) I have been told that when the electricity cycles is different, it may retard the timer. If the electricity cycles is the problem, is there any solution?; if it is not the electricty, what could be the solution?
  • Enrique Mosre Apr 01, 2006
    Windman:
    Thanks for you reply, but transformers do not change the electricity cycles (see the following links for explanations:)
    http://www.international-electrical-supp...
    and
    http://www.interpower.com/icl/p25info.ht...
    Quimos
    Champion:
  • 277 Answers
Hi the Electrical Requirements of this device: 15 OR 20 Ampere, 120 Volts, 60 Hertz (1/second). go to elctronics shop with these details and buy a transformer wich will translate your current Volt\ampere\frequency to what the device needs wich from what i understand needs higher frequency http://www.whirlpool.com/catalog/product.jsp?parentCategoryId=113&categoryId=115&subCategoryId=116&productId=218&view=2#tabs good luck
Posted on Mar 27, 2006
SOURCE:
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    I need a night light timer that I can set to be on for 50 minutes and off for 10 minutes and repeat this every hour for 24 hours.
    1) If you have programmable timer, then it would require 24 ON and 24 OFF settings, with down-to-the minute programming.
    1 ON for each hour.
    1 OFF for each hour.
    Following link shows Grasslin 50-60 Hz 230Volt din rail timer with 50 memory slots. 16 amp at 230 volts
    http://waterheatertimer.org/pdf/talento_371_372_371_mini_plus_data.pdf
    2) If you have 24 hour mechanical timer with dial, it would need 24 ON trippers and 24 off trippers with down-to-the minute schedule.
    No timer has that capability.
    3) There is C8800 series cycle timer. 120-240Volt 60Hz for US market. 20 amp at 120volts, or 20 amp at 240Volt. Chose 1 hour cycle, then insert 100 trippers and leave 20 blank spaces.
    http://waterheatertimer.org/pdf/027-C8800-sprinkler-cycle-timer.pdf
    4) There are percentage cycle timers.
    For example CT2000. Rated 120Volts 60 Hz for US market.
    http://waterheatertimer.org/pdf/CT2000_sell-sheet-with-wiring.pdf
    Select 1 hour cycle, and 16% or 84% percentage to choose ON or OFF
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
    Nov 28, 2012 | Woods Indoor 24 Hour Night Light Timer...
    How can i change the power from 110 volt to 127 volt, jamaica is 110
    Voltage is not the problem. The issue is a 60 hz machine in a 50 hz country. The fix is to buy a Jamaican washing machine.
    Mar 03, 2012 | Daewoo DW500M Top Load Washer
    My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
    Hello there:
    If your cycle does not complete or The cycle doesn't advance
    When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
    Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
    22432 won't spin or drain
    CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
    Aug 30, 2009 | Kenmore 22422 Top Load Washer
    Spin/rinse cycle quits
    it may be an intermittent door lock switch. i believe on your model when you remove the front access panel you will find a pair of wires in a plug with nothing attached to them on the r/h side where the wire harness runs. when you are in the spin cycle, check with a multimeter for 0 volts across the 2 wires. if you are showing 120 volts, then your door lock is bad. if yours has never been changed it actually has been updated to a new style. costs about $120.00 for the part. instructions should come with revised part
    Aug 20, 2009 | Washing Machines
    Nec nw-891 washing machine will not complete the programmed cycle
    Apparent malfunction in the timer circuits. Specific Component replacement not available.
    Jun 30, 2009 | Washing Machines
    Whirlpool GHW9400 Front Load Washer Logo
    101 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
