Question about Zoom X6 (5590) DSL Modem (55900003)
X6 won't pick up DSL
Just purchased a new Zoom X6, all green lights are on apart from the DSL which keeps flashing.
Plugged my old netgear router back in and it picks up the dsl straightaway as does the really old usb adsl modem I have.
Checked all connections to router, ensured everything is set up as per instructions but still the DSL flashes away.
  • Anonymous Oct 13, 2008
    Mine does exactly the same. It worked fine for about 3 months and now fails to connect.
    Genius:
  • 1,605 Answers
Hopefully you haev installed the software first on yoy computer>
turn off the computer. connect the phone line one end to the ethernet port on your computer and the other end to one of the LAN port on the x6.
power up the (power cube shipped with the X6), the Pwr and the WLAN should come on and become steady, the LINK light should blink,
turn on you computer, connect a new phone line between ADSL port and the wall jack, the LINK light should become steady.
please rate the answer if it solved your porblem.
thank you
Posted on Oct 16, 2008
Laptop stopped picking up Internet. Went in other room and the desktop couldn't find internet either. Logged off both and checked the Netgear box and the lights were all yellow, not green. There isn't...
Unfortunatly, if it won't even power up anymore, there no way to even diagnose what the problem might have been. sorry to say, but i think it may be time for a new router.
Mar 04, 2011 | NetGear RangeMax NEXT WNR834B Wireless...
Netgear DG834G wireless router wth built-in modem doesn't connect
Check if you have types all the configurations properly, namely Encapsulation / user name n password.
Jun 21, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
The dsl light keeps flashing green or yellow on my netgear dg834 v5 router n i cant get on internet but it works with my netgear dg834 dg834 v2
The fact that it works ok with the dg834 v2 means you have a DSL enabled line and also connection to the internet
You also have all the configuration details within the V2 Router - you will need to know your ISP account password
Now on the V5 router - do a factory reset - theres a small hole at the back of the router 1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot.
Mar 19, 2010 | Computers & Internet
I have the Zoom X6 (5590) DSL Modem, trouble using software
You may check the following:
1. Make sure to plug the power cube into a power strip or wall outlet and then plug the power cube's other end into the modem's power (PWR) jack.
2. You should only use the power cube with the Zoom X6. Other power cubes may damage your hardware.
3. Try another wall outlet.
4. Reset the modem. Use a paper clip and insert it into the RESET pinhole in the modem's back panel and press it 3 times. Then turn off the modem for a minute and turn it back on. Check if the power light will turn solid green.
5. Possible defective modem.
Hope this helps! Good luck!
Dec 12, 2009 | Zoom X6 Adsl Modem/router Rohs...
DSL Flashing
You dont need both. Do the following:
Unplug your speedtouch from the phone line at the back of the speedtouch unit. Plug that cable into your Zoom. Then plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Nov 23, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
DSL light flashing constantly
I had the same problem to begin with. Here is what the Zoom helpdesk suggested:
"To force the dsl light to stop blinking, please follow these steps.
1) Open up your web browser and type 10.0.0.2 in the address bar. Type in the the username and password to log in to the modem.
username: admin
password: zoomadsl
2) When you get to the address bar, Click on advance setup.
3) Click on ADSL Configuration.
4) Change the standard to G.Dmt and change the activate line to Start.
5) Save changes and then write settings to flash.
Within a 1 or 2 minutes, the dsl light should go solid."
This worked for me. Good luck.
Mar 24, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Zoom X6 internet light constantly red
the internet light, is usually a blinking green, showing that it's seeing the internet signal. The only reason it's red, is cause there's no net signal..double check the phone line going into the back of your router, and change it if you need to.
check your computers warranty here 4 FREE
Mar 16, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Zoom adsl x6
If the Internet light is off it means you are not either authenticated at your provider or your configurations are wrong on the modem. If you go to your command prompt and type ipconfig and check your IP address and your default gateway. The IP address on your default gateway would be your router put that IP address on your browser and should be able to see your modem setting and any error messages that could help resolve your issue
Feb 18, 2008 | Zoom X6 Adsl Modem/router Rohs...
ADSL X6
presuming that the router moved with you the telephone line socket could be too far away from the BT socket or is not correctly wired. if you have not moved the router then you need to buy a booster
Problems with xbox 360 wireless adaptor, finding zoom x6 router
For this problem use http://zoom.custhelp.com/cgi-bin/zoom.cfg/php/enduser/std_adp.php?p_faqid=929&p_created=1193678463&p_sid=NcYTzXmj&p_accessibility=0&p_redirect=&p_lva=929&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjEsMjEmcF9wcm9kcz0yNSwxMjcsMTY5JnBfY2F0cz0wJnBfcHY9My4xNjkmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PVdpcmVsZXNz&p_li=&p_topview=1
Oct 15, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Zoom X6 (5590) DSL Modem (55900003) Logo
382 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
