Question about Tricity Bendix Dryers
Tricity Condenser drier
My Drier is gwtting hot but not drying clothes, I have cleaned all filters in front is there any others I should clean ?
I suggest that you check your belt that turns the drum ,myine was the same ,until i found the fault ,i rang a dealer and fitted the belt myself .if the belt is broke it will not turn the drum ,but it will still heat up !!
Posted on Oct 19, 2008
    President:
  • 1,462 Answers
Clean the condensor itself
Posted on Sep 10, 2008
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
How can I reduce the humidity of the air expelled from the dryer?
If the aire being expelled is humid then this suggests that the unit if working fine. if clothes are still damp then maybe give them a second spin before putting in the drier, or dry them for longer. Also try putting less in the drier and drying in two loads.
Oct 19, 2014 | Miele Novotronic T230C Electric Dryer
My drier gets warm but not hot???whats wrong....I check exhaust system cleaned it and vent system too. power is normal I put it on express drying too and warm not hot?
Most electric driers have two heater coils, inside that provide heat to dry the cloths. Wires like in a light bulb only bigger. I suspect one of these coils is burnt out and thats why it is only getting warm not hot. Also be sure to remove the hose from the back of the drier and check for a restriction there.
Oct 08, 2010 | Kenmore 63942 Dryer
My Neff drier isnt drying my washing it is hot but the
Is the fan working? this blows air across the element which in turn cools the steam into water then pumps it out via pump,Hope this is of some help
Apr 13, 2010 | Neff V4380X0 Front Load Washer / Dryer
My dryer gets hot but does not dry efficiently. Clothes are still very damp after more than 1.5 hours. I noticed that the lint trap is not really gathering any lint.
your problem might be in the actual vent to the outside. If the vent to the outside from the drier has a clog and will need to be cleaned. Without the proper ventallation the clothes will not dry. I suggest pulling the drier out and removeing the vent hose that connects to the outside and clean it. Once this is done you shouldn't have any problems
Hope this helped
Dave
Feb 23, 2010 | Whirlpool LER4634J Electric Dryer
Hotpoint tdc 30 not getting hot enough to dry
Remove and clean all filters, and make sure you have the correct heat setting selected
P[lease rate my solution.
Thnks.
Nov 15, 2009 | Hotpoint TDC32 Electric Dryer
AC repair
If it is low in freon then recharging is the solution. Hot air blowing can be due to, as you have said, low freon, dirty condenser fins or blocked filter drier. Make sure condenser is clean. Use brush to loosen the lints and dusts then flush it with a pressure washer. Blocked filter drier must be replaced and so with the freon. You will know it when frost appear on one side of the filter.
Aug 23, 2009 | Whirlwind FH-778 Air Conditioner
Electric drier takes 2 to 3 cycles to dry one normal size load
Have you tried cleaning the actual inside of the drier?
When you use drier sheets the wax on the sheets melts onto your clothes and makes them soft, but the wax often gets stuck in the holes of the drier making it incapable of drying the clothes in one load. Try scrubbing the inside of your drier with some hot water.
Apr 13, 2009 | Roper REX3614KW Electric Dryer
My dryer is giving off a strong odor. Smells a little like rubber or metal on metal. It still works great. Is still getting hot and drying clothes. Can you help? Lg washung machine/dryer combo(front...
Sounds like drive belt or drum supports, if the drier is gas I would check it out, could cause a fire, if it is electric still check to make sure it is not rubbing on the electric heat element, or it could be full of lint which is catching fire during normal operation and melting or burning the belt or drum supports.
Nov 04, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dryers Logo
109 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
