Question about Canon PIXMA iP3000 InkJet Photo Printer
Printer sat for a while without use. Replaced black inc k cartrage (and yes the cover strip was removed). now black ink will not print. Color prints fine Any ideas?
Try a print head deep cleaning. It should be an option in your maintenance settings.
Posted on Sep 03, 2011
SOURCE:
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
My daughter loader a black ink cartridge without removing the cellophane tape. The printer is now flashing the check black ink cartridge message. We have tried reloading the cartridge properly. Still not...
here is what you do .
1.first unplug the printer ,and shut down you computer .
2.then open then printer cartridge area. remove both color & black cartridges
3.check the black cartrage ( the head of cartrage is it damaged ,,, i mean it should just be like glass surface no ups and downs .. if the cartrage is ok then (youdont have to change it )
4.power on you printer without loading any cartridge .
5.now unplug again and insert cartridge only black .and plug your cartridge .( note PC will turn off in entire procedure) and let your USB cable out of the printer
6.turn on your PC when you see the desktop insert the USB cable. and let the process happen ..!
7. give out print command
i hope that will solve your problem !
do vote /write if it helps you
Apr 04, 2011 | HP Photosmart C3180 All-In-One InkJet...
Will not print black inc, brand new ink cartrage
Try trowing your printer out the window, the same thing happened to me and thats what i did and it seems to work fine now, well i mean after i bought another one i mean.
Aug 11, 2010 | Brother MFC 490cw Color Inkjet...
Hp laserjet 2600n printer creates 1/2" wide band that you can almost see the print...like it is not getting toner in black color.
This often happens when cartrage has run past changing point. remove cartrages starting at top and CK for ink. Run cleaning page until clear
Jul 04, 2010 | HP Color LaserJet 2600n Printer
Replacing a cartridge
Title:
I replaced my ink cartridge, but the LCD is still displaying "Ink Empty". What can I do?
Description: This is typically caused by an incorrect selection made during the LCD prompting after a cartridge is replaced. When an ink cartridge(s) is replaced, the LCD will ask, "Have you removed Blck? 1 Yes 2 No". This question will be asked for ALL 4 colors in sequence, regardless if the color was replaced. If "1 Yes" is NOT selected for the color(s) that was replaced, the LCD will return to "Ink Empty". Do the following to clear the message:
  1. Pull the scanner cover release lever located below the control panel and lift the top cover.
  1. After 15 seconds, re-close the top cover and then re-close the control panel cover.
  2. The LCD will then display Have you removed Blck? 1 Yes 2 No.
    The LCD will display this question for ALL 4 colors (not just the ones replaced). BE SURE to select 1 YES for each ink cartridge that was replaced.
    If 1 Yes is selected, the LCD will then display Change to new (color)? 1 Yes 2 No. Again, BE SURE to select 1 YES.
Note "Change to new (color)?" will only appear if 1 Yes is selected for "Have you removed (color)?" If 2 NO is selected for the "removed" question, the LCD will then move on to the question for the next color.
Oct 11, 2009 | HP Photosmart 3310 Printer
Color ink cartridge says empty i just filled it
When you put in a "new" cartrage the printer sens an electrical charge to the cartrage to set it up properly. So I would treat this as a new cartrage, rather than a refilled one. Go to the printer menu and re install the ink cartrage in question, it should recognise it and start the function as a new one, good luck
Mar 24, 2009 | Epson Stylus CX6000 All-In-One InkJet...
HP 930C will not print in color
Have you made sure that the plastic strip covering the cartridge is removed? Also, are both of the cartridges installed? Mine won't print if both aren't installed. Next, you might want to check that (in printer settings) your printer isn't configured to print pure black/greyscale. Otherwise, check the HP Site, they have walkthrough guides on how to print tests directly from your printer. Hope this helps. BurntLime
Dec 16, 2008 | HP DeskJet 930c InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Then your point is i should buy a new set of color cartrages like the 3 colors before the printing should take place then how can i set my brothers printer mfc-240c into black cartrages only no need to buy...
First - read the manual as regards printing. I notice that you can print in Black and White but I cannot find anything to say that you only need the Black ink to do this (therefore I think that I am right in saying that you need the colour cartridges).
Question - Has it worked with only the black ink before now?
As a final solution - Contact Brother direct and check out their FAQ's and/or send them an email asking if you can run the printer with Black ink only installed (I suspect the answer will be no).
If the answer to the above questions comes back as "Yes you can use Black only" (they may tell you how to set this up in which case ignore my next comments), then please supply some more information as regards what happened immediately before it stopped printing. This will help to drill down to the problem.
May 11, 2008 | Brother MFC 240C All-In-One InkJet Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
47 people viewed this question
Clive
Clive
old marine
old marine
