Question about Maytag MMV5165 Stainless Steel 1000 Watts Microwave Oven
Maytag Microwave Can you advise how to remove the Control panel and keypad. I have the new one on order?
  • 76 Answers
Open the mic and take off the hole pannel,you will see plastic like clips that you just need to press out.
Be cearfull not to bend the new pannel,they brake like nothing...
Good luck.
Posted on Sep 09, 2008
Error code showing
Unless there is grease or moisture on the control circuit board, error code "SE" means you have a shorting membrane keypad.
On this model, the membrane keypad is not available as a separate part, so the control panel frame assembly (which comes with a new keypad) would have to be ordered and replaced. It's actually a pretty simple DIY repair.
It is part number W10258189 and you can get it for about $129 (subject to change) from the Pros here.
There is also a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad as per the photo below.
keypad_connector.jpg Some connectors have a lock.
Then move your circuit board into the new frame. Be careful, the display is made of glass.
Dec 03, 2013 | Maytag Microwave Ovens
I have a Maytag Microwave/Hood MMV4203DS00. Twenty minutes after its last use as a microwave oven, the Vent Fan spontaneously went on and the Display Shows: VENT...FAN..--5E-- (or SE?). The microwave...
"SE" error means you have a shorted membrane keypad.
The frame assembly is part number W10258190 and you can get it for $67.98 (subject to change) from the Pros here. You can also order the thermostat (part number WB27X10567 ) from them.
Their is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors on the relays have a lock:
positivelock.jpg Then move your circuit board into the new frame. Be careful, the display is made of glass.
Sep 01, 2013 | Microwave Ovens
Maytag Over the Oven Microwave Model MMV5100AA display shows "SE". All touch pads are inoperable. There IS power to the unit.
"SE" means you have a shorted membrane keypad.
You did not give us the full model number. It will be one of these:
MMV5100AAB
MMV5100AAQ
MMV5100AAS
MMV5100AAW
On these models, you would need to order a control panel frame which comes with a new keypad already installed. It's a simple do it yourself fix.
You can look up and order that part from the Pros here, our favorite supplier. If it's not in stock immediately, they will have it to you in a few days.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Aug 17, 2011 | Maytag MMV6186W Microwave Oven
My maytag microwave keeps beeping it will not let me set the time or warm up anything. it keeps showing SE where the clock time should be
On some models, you can replace the membrane keypad.
I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
On some models,
the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Some connectors on the relays may have a lock:
Jun 20, 2011 | Maytag Microwave Ovens
My Maytag microwave has error code "SE" on the
SE error means you have a shorted membrane keypad.
The full model number would be MMV1153AAB or MMV1153AAW and denotes color.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly ("control panel/switch" as it's called) which comes with a new keypad.
It's actually a pretty easy do it yourself job.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Some connectors have a lock:
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
You can get the part from the Pros here. They're our favorite supplier.
You can also find helpful exploded view diagrams at that link.
Apr 27, 2011 | Maytag MMV1153A Microwave Oven
The microwave does not operate and shows an F2 code. What is the problem?
F2 on a Whirlpool / Maytag microwave means you have a shorted membrane keypad.
On some models, the keypad has to be peeled off and replaced, but on others, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
Please make a new post with your full model number and we can tell you if yours is one of these models, and if so, we'll also give you the part number you need to order and a link to the best priced supplier.
Either way, we can let you know what your options and costs would be and send you other helpful info.
Or feel free to contact me directly
(and please remind me of your full model number from the tag on the unit) for more information & help.
Jan 26, 2011 | Whirlpool Microwave Ovens
A GE service man advised that our two year old microwave model JVM1540 DN1WW requires a new key board that coat $222.23, Is this normal for a GE product? Charles Myers email: cmyers07@comcast.net phone:...
This is a common failure.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It is part number WB56X10824 and you can order it here for $115.94 They're our favorite supplier.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame. Be careful - the display is made of glass.
Dec 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
3 yr microwave just turned off after use. Would not accept any buttons pressed. Checked fuse and turn off and on, but microwave does turn on....please advise.
If the fuse were bad, the oven would be totally dead.
The rest of my answer assumes a model number of JVM1750SMS01 / JVM1750SM1SS.
You have a failing membrane keypad.
The part number to order is WB07X11054 and you can get it from the Pros here for $129.93 plus shipping. They're our favorite supplier.
Oct 02, 2010 | GE JVM1750SMSS Microwave Oven
Microwave turns on & control panel is frozen. F2&PAN error codes
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number (KHMS155LWH1 without dashes) from the tag on the oven here.
Jun 09, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Sharp carousel Model R3A36 keypad not working. We had a brown out due to a recent storm and the microwave keypad didn't work anymore after that. We unplugged and replugged and the light inside is...
Your keypad has failed.
It would need a new control panel frame, which comes with the keypad.
You simply remove the circuit board and plug it into the new frame.
It is part # FPNLCB070WRK0 and the best place to order Sharp parts is Tritronics.
Sep 03, 2008 | Sharp Microwave Ovens
Maytag MMV5165 Stainless Steel 1000 Watts Microwave Oven Logo
137 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
