Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
Blue Spots on my Zenith D52WLCD TV
I have had this TV a little over a year and the blue colors are really starting to stand out. Is this a problem that anyone has come across and can it be easily repaired? Any help or pricing would help.
  • 1 more comment
  • scottedgell Feb 09, 2008
    We have a similar problem with a blue tint going down the left half part of the screen about 6-8 inches from the top. The bulb is is great shape. Why are we getting this blue tint and how do we fix it.
  • buck_2009 Dec 31, 2008
    I have the same problem, the blue screen started on the top right corner of my TV and the replace lamp came on the screen so I replaced the lamp and the blue has now covered the whole screen. I can see the picture but the blue tint is getting worse. Is there a pace I can take the TV to get it fixwed or should I just buy a new TV?
  • challharris Jan 07, 2009
    The picture start with a blue in the corner then move to the whole screen now we have a yellow circle right in the middle of the screen. What can we do? Inside the yellow circle or black circle we can see the real colors of the screens. please help the... We have only had the tv less than 4 years
    President:
  • 3,130 Answers
Are these blue spots as stated in the first line of your complaint or is the blue over powering the rest of the picture?? And are they spots or small blue particles?? Need more info please!
Posted on Mar 24, 2006
White arcs across screen when the screen is dark or black.
Replace a color gun in your KP51HW40. Then adjust the picture brightness to eliminate these rings by turning a little button behind the front (cloth like) panel (the one covering the front bottom half of the set). You may have to to dim the lights to be able to do that properly. The little dial button as is in the middle.
Jul 03, 2010 | Sony KP-51HW40 51" Rear Projection...
I have some distored blue color across the screen
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
Green/Blue distorted Colors
Color issues are harder to solve without seeing the problem. It sound like the red amplifier on the crt board is bad. Is there any red in the picture at all? If not, that will be you problem
Nov 26, 2008 | Televison & Video
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Bad Color - Not much red
picture tube is goin bad............
Dec 28, 2007 | Sony KV-32S26 32" TV
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Color problems at top and bottom of screen
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.eserviceinfo.com/
http://www.digitalhome.ca/forum/search.php
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 17, 2006 | Hitachi 42V715 Rear Projection Television
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
413 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
