Washing machine when on drain wont drain the cycle wheel keeps turning looked in the manual this states a fault , have drained the water out of pre chamber/pump . the cover will not rotate it appears to be blocked dont know what else to do ?
  • Anonymous Sep 09, 2008
    washing machine won't spin and has odd noise when pressing start
    Novelist:
  • 166 Answers
Peace Friend,
ngafm At your service!
Things wear out! So is life!
Sounds like the coupling between the transmission and the agitator is the problem!
Only a hands on laundry tech can make the diagnoses
I were there hands on i could repair it.
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Sep 09, 2008
The washer faults during drain cycle. I have cleaned the filter. It is pumping fine with plenty of water flow but still faults out.
Maybe a short or oxidation.It could use other programm's drain cycle instead of the pre-set.You are washing cotton and it drains syntetics.
Mar 20, 2015 | Whirlpool Duet WFW9150WW 4.0 Cu. Ft. Front...
Manual zanussi essential 1400
You have a bad Drain Pump! It needs replacing. Unplug the machine first, Drain all the water out.
Jan 19, 2014 | Washing Machines
Fisher and Paykel washer will not drain after the wash cycle, have to bail the water out until there is only about 3 inches of water left in tub, then it will drain and continue with the load. We have...
Hi just read your posting.Now when the machine is full of water and the machine finishes the wash cycle do you hear the pump trying to pump the water out or silence?Does your machine have a diverter valve fitted?My service manual states that the problem could be the control module.Could you please reply back with answers to the questions and with the model number and I am sure I can help you rectify this fault.Looking forward to your reply.
Jun 02, 2011 | Washing Machines
My whirlpool front loading washing machine keeps stopping before the rinse cycle. I've cleaned the filter and the drain hose as well as all the inlet hoses. It stops and all the lights flash and it wont...
While it stops to rinse , does it drain off? if not there is block on the drain valve and so there is an error on the board because the water level sensor has to switch OFF and then ON to confirm that water has come in for rinsing.
So if the cycle is absent the possible fault can be the program controller. So you need to check the actions when the fault occurs, check for drain,.then after drain the inlet valve must open to allow water and then the water flow must cut off to start the motor.
If there is no action and output then the controller can be defective.
Apr 12, 2011 | Whirlpool Washing Machines
Kenmore 11020432990 washer wont drain water after wash cycle. it still spins but wont drain water
sounds like the drain pump is not working,, remove the back panel from the machine and with a volt meter check for voltage at the pump when it is in the drain cycle. if you do have voltage then the pump is at fault. but if you don't have voltage then the problem could be at the controls.
c...
Feb 02, 2011 | Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
ASKO D3432XLB keeps running, draining but hasn't gone into the wash cycle yet. won't turn off even when I turn the power button off.
Water on lower bottom. Leakage or blocked drain pipe. Is common error. The machine will act like this so that water wont get on your kitchen floor, in case of fault on inlet valve. The machine indicates overflow. Dry out water on bottom, and than the machine will work normaly. But check for leakage. Just in case.
Jul 18, 2009 | Asko Dishwashers
Water won't cut off on super load
yes raise your drain hose up. do not shove it down the drain to far or the bottom of the hose will be below the water level in the machine. it is called siphoing. you can hear it by shutting the machine off when it is at the cycle you stated and hear it draining. pull the hose up and secure with a strap.
May 17, 2009 | Washing Machines
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
