Question about Kitchen Ranges
I have recently had a corgi registered plumber remove a gas fire with back boiler from my living room and he blanked off the supply as we no longer require a fire in its place. we also have installed a new gas hob. he did a gas leak detection and found we were loosing gas so he disconnected the hob and this seemed to have solved the gas leak on doing another test pointing to a problem with the hob or the micro hose. I bought a new micro hose and this still hasnt been fitted but since the guy has made these changes my gas oven seems to be producing an awful smell of gas whilst on. when i open the oven door the smell and fumes really stings my eyes. what can the problem be.
    President:
  • 1,462 Answers
IMMEDIATELY ISOLATE THE OVEN AND DO NOT USE. GET PLUMBER BACK - HE SHOULD BE ABLE TO CHECK THE APPLIANCE ITSELF FOR LEAKS BUT THE MOST LIKELY CAUSE IS THE JUNCTION OF THE CONNECTION HOSE WITH THE HOB
Posted on Sep 10, 2008
There is no power going to the pump in my boiler
Power to the pump goes via the room stat in turn from the programmer check these out first
Apr 22, 2013 | Water Heaters
Vaillant boiler has a strange odor when firing up
It could be the heat exchanger overheating or a problem with the chimney. Both require that a qualified service tech evaluate the problem because both can cause carbon monoxide to be released into the living area. THIS NEEDS IMMEDIATE ATTENTION!!!!!!!!!!!!
Mar 25, 2011 | Honeywell Heating & Cooling
Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Feb 01, 2010 | Desa International CBN30T Central Heating...
Exactly the same problem
what u need to do is turn off all your rads except the 1 that is working and run the heating that should push any blockage round the system do the same with other rads that are blocked then try bleeding the rads and filling boiler if neccecary
Jun 06, 2009 | Combi Centre DX - Mango
Baxi solo 2 30pf will not fire up.. please help!
first off ensure water is getting to boiler, next, No pilot = pressure switch. On my baxi solo 40 pf pressure switch is replaced 8-10 times a year cures your problems,,,,,,,, momentarily , and have had all your other parts,but with no effect to speak of,.......sorry............ solution = [ change boiler ].sounds like gas pressure or lack of water to system or **** boiler like mine .........good luck.
May 15, 2009 | Water Heaters
Pilot light on boiler
The plumbers repair should be guaranteed, give him a call back.
It sounds to me that the pilot flame needs to be adjusted or the thermocouple is not aligned properly or there is a draft that is blowing out the pilot.
Good luck...
Feb 22, 2009 | Water Heaters
Water gets hot then turns cold and runs cold then hot again
Secondary heat exchanger is blocked on sealed system side.
Remove and de-scale heat exchanger or fit new one.
Feb 04, 2009 | Combi Centre DX - Mango
Valient combi boiler is not heating the water properly
vailant boilers are one of the best on the market and should last you more than 6 years depending on installation and servicing.
the engineer you had should not have replaced the diverter valve if the boiler was firing up when the taps are opened. if you was getting luke warm water with the boiler alight it is a classic symptom of a blocked plate heat exchanger on the central heating side.
a new heat exchanger can cost around £100 depending on the age and model of the boiler.alteranatively it could be descaled but may clogg again. it would be a good ideal to fit a magna clean filter on the system to help prevent further debris if you have a dirty system .if you don't trust your engineer i suggest you ask another. find out if he is registered first and don't pay until you are satisfied with the work. if you are asking the same engineer back try and get a discount off the work as he has failed to rectifiy the original fault and fitted the wrong part due to wrong diagnostics. if he is registered you can complain to the governing body ie corgi or gas safe register.
good luck.
Jan 16, 2009 | Water Heaters
Thermocoupling on a Honeywell Economy Plus EP50B Boiler
the thermocouple most likely plugs into the gas valve, the box with the gas control on it.
Jan 10, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
My gas oven flame
BLOCKED JET MAYBE CAUSED BY FOOD SPILLAGE OR BLOCK IN PIPE TO JET
May 28, 2007 | Parkinson Cowan SG320 Gas Kitchen Range
Kitchen Ranges Logo
194 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
