Question about Vizio L32 32 in. LCD HDTV
TV NOT WORKING
SCREEN JUST WENT BLACK WHEN WE WERE WATCHING TV.STILL HAD AUDIO BUT NO VIDEO NOT EVEN COMPONENTS OR MENU BUTTON WORK
  • Anonymous Sep 15, 2008
    I have same exact problem -
  • Anonymous Oct 27, 2008
    We have had our Vizio for about 3 weeks now, today the thing just went pitch black with only the channel description available with no sound. Lame!
I have the same problem.
Posted on Oct 24, 2008
    Problem Solver:
  • 14 Answers
If you have no menu the tv needs service. Internal problem that cant be fixed with troubleshooting or settings...:(
Posted on Sep 15, 2008
Blue screen no signal
Posted on Sep 11, 2008
I have a 55 inch JVC tv,today the screen went black but still have sound, also the buttons on the back wont work, but the channel down button turns it on and off? What is wrong with it?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary..
Jan 15, 2017 | JVC Televison & Video
While I was watching my Emerson TV I heard a loud click and the screen went black and audio went off. When I press tv button on cable remote the tv button glows red, and nothing happens on the tv.
Hi the power supply might have shut down through overheating turn the power of at the wall socket & wait for a short time before trying again the TV might reset itself if this doesn't work its probably shut down from a faulty component. good luck
Oct 23, 2016 | Emerson Televison & Video
Component video problem. Hi I got the Denon AVR-3806 receiver and has it hooked up with a component cable to my background projection TV. To the reciever I have a satellite box connected also with a...
Just fixed this myself - made my head hurt to figure out. 1. Switch to a setting (say DVD). 2. Watch the AVR screen as it switches. You'll see the audio and video settings. For example, Audio = DVD, Video = DVD (Mine showed Audio = DVD, Video = DBS even though is was set correctly using the SETUP for audio and video)3. Under the round control knob on the left, push the (tiny) Video Select button. 4. Turn control know to choose the correct video source
Your system should work right. Mine did.
Jan 03, 2011 | Denon AVR-3806 Receiver
TV screen shows static
change the input back to what it was before he got ahold of it .
Aug 12, 2017 | Emerson EWF2004 20" TV
My 46-inch Samsung LCD TV screen went black. Audio works.
If you are seeing light then the back light is working. Can you get a menu?Do any of the other video inputs work? If no video but has backlight and no men or any on screen display replace main board.
Sep 13, 2009 | Televison & Video
My television screen went black, but there is has sound
Make sure your tv is on the right input first of all. The newer flat panel lcds combine the componenent video (red , blue, green) with the composite video and audio (yellow, red, white). If your tv is on the component input then you hear audio from the composite input since the audio inputs (red, white) are shared. Look for a source or tv input button on your remote or the tv itself and try pressing this button unti you see a picture with sound.
Aug 15, 2009 | Televison & Video
Toshiba Regza screen is black but audio works
I unplugged everything and then reset-up the tv, dvd player, audio, and other components.
Dec 29, 2008 | Televison & Video
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Have Audio, and backlights, but still no video on Polaroid 3732
try the diffrent inputs HDMI Composite component and see if the video comes on there are 4-10 diffrent inputs on these sets and make sure you select the right input on the menu the remote has a button for inputs a menu comes up and make your selection from there for the right input that you have connected to the tv most menus have TV (air) HDTV (air) video 1-6 HDMI and VGA
Jul 02, 2007 | Polaroid FLM-3732 Television
Vizio L32 32 in. LCD HDTV Logo
311 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
