Question about Samsung SyncMaster 740N 17" LCD Monitor
18 inch monitor; Brightness popup
Will not disappear even though I have used the onboard monitor buttons to try.
  • samsung743 Dec 01, 2008
    Same problem here! Thousand Samsung users have same problem..
  • sahnisam Feb 05, 2009
    The brightness box pops up on the monitor's display and pops in and out like it has a mind of its own. It's a Samsung Syncmaster 720n.
I have the same problem with my Samsung SyncMaster 720n, the brightness window pops up without me touching it, and never dies down.
This delicate panel is affected by any decibel or temprature change (like humidity in my case), it can drive us all mad.
Here is a picture while I'm writing to you all:
I was thinking about using some WD-40 (penetrating oil) with the panel, but I'm not so sure it is the best solution.
Does anyone have a better solution?
Posted on Sep 18, 2008
SOURCE:
Change brightness
The second button from the left on the bottom corner by the power button is the brightness button. If you press it the brightness menu is pop up on the screen. With the menu up you just use the three buttons on the left to select the function and the increase or decrease the brightness and contrast on the monitor.
BuddyMc
Aug 07, 2013 | Dell E178FP 17 inch LCD Monitor
Samsung monitor brightness indicator stuck in middle of screen and won't disappear
its an option pyshically on your monitor there has to be some butttons near the power button of the monitor. play around with those and you might figure it out or
http://www.eanswer.com/tv-repair/?r=ppc'ga'9'HI%20-%20Electronics'TV%20Samsung&JCLT=Samsung&JPKW=samsung%20screen&JPDC=S&JPST=&JPAD=5822362509&JPAF=txt&JPCD=20100518&JPRC=1&gclid=CPqM5LPxlLUCFYVFMgodOiUA5w
if this helps please take time to rate
Feb 01, 2013 | Computers & Internet
Brightness/contrast menu popup
Sound like either the button is stuck or the display is in error.
press and wiggle the buttons carefully, and disconnect the power to the display.
Feb 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Need help with Compaq MV5500 CRT 15 inch monitor
hi there, your switch botton is failling, manual buttons on the front to adjust controls, do some switch test, replace micro botton switch. ty
Dec 26, 2007 | Gateway FPD2275W LCD Monitor
Birghtness 100 Popup
sounds like your "brightness" button may be stuck. try pushing it and see if it feels the same as the other buttons (should feel it "click" a bit). Also see if any of the other buttons work, because if it IS stuck, they probably won't work...
Nov 29, 2007 | Samsung 710N V2 17" LCD Monitor
Popup on monitor screen
first try unplug set from AC plug for about 10 seconds for full system reset.If not see if firmware (software) on set could be updated to newer version software...could be a software issue..
Nov 28, 2007 | Samsung 710N V2 17" LCD Monitor
Adjusting Brightness on Acer 17 inch monitor
you change the settings manually using the up and down arrow buttons or plus or minus buttons mounted on the front of your monitor you dont need to use mouse.
Apr 04, 2007 | Acer AC711B 17" CRT Monitor
Samsung SyncMaster 740N 17" LCD Monitor Logo
451 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
