Question about JBL PSW-D110 Speaker
JLB PSW-D110 Subwoofer Issues
HI,
C6 on my PSW-D110 blew up. I replaced it with a 100V, now I get some low frequency hum for about 10 seconds and then the fuse blows. Can you suggest any other parts which I should check besides the C6. Thanks, Pat.
  • pj_cow Sep 09, 2008
    I don't understand the solution. Grounding may be an issue but would this cause the fuse to blow?
  • 10,594 Answers
Hummmm is from Output amplifier and you need to replace it because power supply blow it too.
Posted on Sep 09, 2008
  • vishwanath
    vishwanath Mar 04, 2014
    Hi sir , My alumni sub woofer company , i attach the image of woofer plz check. Which have problem that it gives sound well but woofer not get coordinate properly and humming what can do? i replace capacitor Which part problem I can Help sir
    Brigadier General:
  • 5,158 Answers
When you replaced the capacitor did you replace it properly oriented. if it is the round can type there is a positive and negative. you should make sure the replacement was also the exact value capacitor that you blew. sounds like it has blown again or there are other capacitors that are in need of replacement. a bad capacitor will give you humming.
Robert
  • 4,234 Answers
I don't recall the exact output section for those units, but I would suspect that either there is a shorted output transistor or the speaker itself is blown. Try disconnecting the actual speaker and see if the amp stays on. If so, let me know. I will try to look up the schematic on this in the meantime.
Dan
  • ABRsvcs Sep 09, 2008
    Hey Pat,
    There was a service bulletin that requires the following parts to be replaced should C6 get smoked. Replace the listed parts and get back to me if you have further problems.
    Dan
    Parts:
    C6 - 10ufd 100V
    C24 - 100nFd 50V
    R23 - 20K 1/2W
    R46 - 47ohm 1/4W
    Please note that the actual power module is no longer available. Lets hope that is not the problem...
    Dan
  • 19,396 Answers
C6 must be 50V, are you sure 100 V will work?
Do you have full schematics?
  • 1 more comment
  • Ginko
    Ginko Sep 09, 2008
    I can see on a forum there is an issue on C6, this had been published on a JBL bulletin.
    C6 must be replaced.
    Try also replacing the C24 cap with a 100nF, 50V cap, the R46 resistor with a
    47ohm, 1/4 Watt resistor, and the R23 resistor with a 20kilo-ohm, 1/2
    Watt resistor.
    The whole set can be ordered from JBL on a kit, Kit part number is 30721.
  • Ginko
    Ginko Sep 09, 2008
    Here you get the service manual
    PSW-D112/DPS-12
  • Ginko
    Ginko Sep 09, 2008
    Genius:
  • 1,142 Answers
Humming is always caused by low earth resistance so check the earthing.
What is the size of the JBL PSW-D110 fuse?
The fuse is a 250volt 1.25 amp slow blo.
First thing I would do is check C6 to see if it is bulge or blown - regardless replace it with a 10ufd 100volt Non-polarity capacitor. If the fuse blows again unplug the blue wires from the transformer and plug in unit to an outlet. If fuse does not blow then problem is on PC board. I have a service manual for this item. Probable causes on PC board are Filter Caps, Bridge rectifier (DBA), Amplifier module, or fragments of C6 even causing shorts on board if it had blown.
I have bought C6 from MCM Electronics for under .50 cents but you have to put shrink tube on one lead and bend it back along the body and solder both leads in the board.
Good luck
Jun 24, 2011 | JBL PSW-D110 Speaker
No output from d110
You can use a cap of same or bigger voltage,
Oct 17, 2008 | JBL PSW-D110 Speaker
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
Mar 25, 2008 | JBL PSW-D110 Speaker
Hi, Here's the problem with my PSW-D110. When I plug in the power cord I get a loud humming sound and the speaker thumps every couple of seconds. Anyone know what the problem may be. Thanks, Tim
I would say it's a case of bad filter capacitors in the power supply. Without the capacitors, the AC power line doesn't get smoothed out enough when converted to DC by the supply, and you hear the hum that gets through. I have never worked on on one of these so I can't tell you how to open the case to get at the supply. It's not always a simple job. But if you can get at those caps and check them, you'll probably find them at fault. It's not a difficult job to remove and replace bad capacitors if you are comfortable using a soldering iron. Just make sure that replacement parts have at least the same voltage voltage rating and capacitance values as the originals. It never hurts to go higher by a little, but not lower.
Feb 24, 2011 | JBL PSW-D110 Speaker
Speaker will not turn on. Is there any trouble shooting I can do.
There is a fuse inside (250 volt 2.5amp slowblow)
Check and replace C6 with a 10ufd 100volt non polarized capacitor.
I have a service manual if you can not find one!
Jan 13, 2011 | JBL PSW-D110 Speaker
Subwoofer will not product sound. (ignore product)
Please verify that we're talking about a JBL PSW-D110 here. I'm making no assumptions.
Are you running the Ipod into its L & R RCA jacks as prescribed?
Have you tried it with something besides the Ipod? A sub isn't supposed to reproduce a full range signal. Come to think of it, is the Ipod even outputting anything within the sub's operational range? I don't expect a lot of real bass comes out of one.
Perhaps you could try adjusting the Low Pass up to 180 to see if anything anywhere near the 'real' bass region is present.
Bottom line: There's not a lot of need for a sub (and no other speakers) running off of any music sound source. You wouldn't hear anything above 180hz.
Nov 28, 2009 | JBL PSW-D110 Speaker
Try replacing parts listed below first. Less that $10.00
C6 kit as an substitute and the parts are as follows:
The part is available
The part is called: CAP RAD 10uF 100V Bi Polar. BU120/BU80
The Part # is: UVP2A100MPD
The price is $2.70 each, plus shipping and handling (For U.S. orders only).
The part is called: RES CF 20K OHM 1/2W For C6 kit
The Part # is: 293-20K
The price is $1.98 each, plus shipping and handling (For U.S. orders only).
The part is called: RES mf 47R OHM 1/4W For C6 kit USE -RC
The Part # is: 271-47
The part is called: CAP MCER AX 100NF 50V For C6 kit
The Part # is: 75-1C10X7R104K050B
The price is $1.90 each, plus shipping and handling (For U.S. orders only).
The part is called: Instructions, Kit (C6 repair) Gen brand
The Part # is: C6KIT INST
The price is $2.01 each, plus shipping and handling (For U.S. orders only).
If you are not in the U.S. please advise where you are so the correct information can be sent to you.
Please add tax if you live in New York (8.25%), New Jersey (7%), Connecticut (6%), California (8.25%), Florida (6%), Arizona (8.10%), North Carolina (7%) & Georgia (7%).
You can order this item by calling us at 800-422-8027, 800-336-4525 and 800-553-3332
Please allow 7-10 business days for shipping
Jun 12, 2008 | JBL PB10 Subwoofer
C6 Polarity?
Hi CALSunbelt
There is no polarity to be conscious of when you are using a BiPolar cap. They can be used in either direction.
regards
Graeme
Apr 06, 2008 | JBL PSW-D110 Speaker
My JBL PSW-D110 started humming loud... The fuse is fine and the power LED displays is illuminated in green. However the sound is unbearable... It would like to replace the entire IC panel if its most cost...
Hi calsunbelt
there are some caps that fail in the power supply. If you are up to doing some electronic repairs, I could talk you through it and tell you what parts to check.
regards
robotek
JBL PSW-D110 Humming Loud
If I remember these correctly, there is a bad coupling cap in the amp section. You should see it as the top should have ballooned up. Replace the cap and you should be OK.
Dan
JBL PSW-D110 Speaker Logo
1,114 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
