Question about Audiovox D1708 Portable DVD Player
Dvd player screen is green
Thanks for your help. My player is a portable device and everything is green not in full color. I think the LCD needs to be replaced.
  • microangelo Sep 09, 2008
    Where can I get the part or find someone to fix it for me.
  • 10,594 Answers
Ok, you are right. LCD drive circuit might need replacement.
Posted on Sep 09, 2008
I have a Craig portable DVD/CD player. It stopped playing sound. What's wrong? Not on mute.
Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote
www.amazon.com/Craig-9...Portable.../B007S71NHM
Amazon.com, Inc.
Rating: 3.3 - ‎58 reviews
Amazon.com: Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote, Black ... But keep in mind this player does not provide the highest quality in portable DVD players one can find. .... The remote stopped working within a few weeks.
Craig 10" LCD Portable DVD Player with Swivel Screen and ...
www.qvc.com/Craig-10-LCD-Portable-DVD-Player-with-Swivel-Sc...
QVCThis 10" portable DVD player from Craig comes with everything you need to help keep ... Plays DVD, CD, CD-R/-RW, JPEG; 10.1" diagonal TFT display; swivel screen design..... Couldn't start DVD unless I held down the door or it would stop.
Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD ...
www.walmart.com/.../Craig...Portable-DVD-CD-Player.../33846...
Walmart
Rating: 3.5 - ‎18 votes - ‎$59.78 - ‎In stock
Buy Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD Player with Remote Control at ... I had one of these portable dvd players but paid over $100.00.
Dec 28, 2015 | Craig Televison & Video
I have the Insignia Dual 7" Portable DVD Player. Model NS-7DPDVD. I'm noticing a yellowish color on the movies. I adjusted the brightness wheels on both but it's not the brightness it's...
Bring up a menu on the DVD player screen (not a DVD menu, the dvd players settings menu). Is this menu also tinted yellow? It probably is, and you probably have a faulty part internally.
Jun 13, 2011 | Insignia Dual 7" 16:9 Widescreen LCD...
Portable dvd play and kid spilt water on it, now the screen is in negative format, how do you fix this?
The main board has been damaged, the water gets into the parts and causes corrosion and oxidizes turning any ic a green color. To attempt a repair the player will need to be unplugged and the battery removed before you dis-assemble the player. When you can see the boards, get some rubbing alcohol and a stiff toothbrush, dip toothbrush in the alcohol and scrub each part carefully removing any green on the boards and parts. After you finish let it dry overnight, and inspect the boards to see if any traces remain. If everything checks, assemble it back together and try the player.
Jan 26, 2011 | LG DVP7772 Portable DVD Player with Screen
This portable dvd player was given to me, he even sent for the wall plug for it...Now I have it and when I turn it on the blue dvd screen does not come on.What come on are large green lines up and down the...
This thing is garbage now sorry,can't be fix.The LCD screen viewing panel is damage by force,like dropping the unit or sometings or somebodies hitting it hard on the LCD viewing screen.The LCD viewing screen panel,will cost the same as a new portable DVD player.This LCD viewing screen panel,must be replaced to solved the problems.The whole new portable DVD player only cost like about 50-60 bucks.
Oct 16, 2010 | Coby TF-DVD7005 Portable DVD Player
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
No user manual for Protron PDV-288 portable DVD player
nahh you cant over chargee silly;; when its done, its done, it just doesnt loose battery power. and im not positive about the light.. but i would most likely assume that when the green light is on, that means its charging.. thats how pretty much every electronic works.. light on-charging; light off-no charge. sometimes it varies by different color lights.
thanks ! hope i was helpful.
Feb 10, 2009 | Protron PDV-288 7" LCD Portable DVD Player
Screen is green when trying to play a DVD
I think DVD player is hooked with TV via component video input.
Check component video connections and make sure each color wire connect in same correspondence color in both units, TV and DVD Player.
Red to red, green to green and blue to blue.
Dec 18, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Dvd player recharger charge status lights blink
The blinking went away as I had charged it for a very long time. However, it was noted that it would not work on the DVD. The battery needs to be replaced. That solved my problem. I still have to look for a new battery for this device: US Logic 680p DVD player with recharging capabilities due to the portability option. It works fine if plugged in, but the battery just needs to be replaced if I want to use it independent of the plug. Thanks for asking how I resolved the issue.
Nov 25, 2008 | US Logic 680P Portable DVD Player with...
MUSTEK 7" pORTABLE dvd PLAYER lcd PROBLEM
You might need to adjust the settings by pressing the LCD button then using the up/down/left/right arrows on the player or remote to change color or brightness. If this doesnt work, your screen might be shot. There isn't much you can do if thats the case.
Nov 03, 2007 | Mustek MP70C Portable DVD Player
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Audiovox D1708 Portable DVD Player Logo
283 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
