Question about Amana Microwave Ovens
F5 error code on amana microwave hdc18 - Amana Microwave Ovens
  • jmn360 Oct 09, 2008
    i get an error 5 and a stand by light
  • Amana Master
  • 9,047 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Next I would check the door switches and mounts: http://www.microwavedisplay.com/safety.txt
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you still have trouble, I would suspect a problem with the controller. We regularly repair these for customers nationwide with our guaranteed $39.95 service.
William E. Miller
prototech@usa.net
Posted on Sep 16, 2008
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Clean the filter on an anna microwave oven HDC18
The service manual (here) covers that.
You can order Amana parts from the Pros here.
Jan 15, 2013 | Amana Microwave Ovens Amana HDC18 - C-Max...
For Model: URC517MP - Can you clarify Error Code C5
Hi ess0,
The Amana error code F5 means that you have a failed Electronic Range Control (ERC. The only way to resolve this problem is to have the Electronic Range Controller be replaced. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
May 31, 2011 | Amana RC17 Microwave Oven
I have a Amana microwave with a f-5 fault code.Model#RFS12SW2
Hi ejv3968,
This means that you have a control board failure. Error code F5 can only be fixed if the control board (ERC) is replaced. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Apr 05, 2011 | Amana Radarange Microwave Oven
How do i program the times on this model?
Need to program cooking times. What are the procedures?
Jan 30, 2011 | Amana HDC18 Microwave Oven
Microondas amana error5
Hi edextre07,
Hope this helps.
Nov 07, 2010 | Amana RC17 Microwave Oven
Spec sheet for the Amana HDC18 and HDC 21. Straight 208 vac 3 wire? Control transformer included or do I have to supply a neutral?
The service manual is at our site here.
Jan 15, 2010 | Amana HDC18 Microwave Oven
We own an Amana HDC18 commercial microwave. Lately, it has begun sparking intermittently between the door and the floor. There looks to be a thin spot in the coating on the floor right at the bend on the...
The gasket holding the ceramic floor plate may be damaged. If so, it will need to be replaced, or clean the area thoroughly and apply caulk.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 04, 2009 | Amana HDC18 Microwave Oven
Microwave Ovens Logo
360 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Mike
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
