Question about Sharp AR 163 Copier
Sharp PHOTO COPIER MODEL No AR163
I HAVE MOVED MY COPIER FROM ONE ROOM TO ANOTHER HAVING SWITCHED IT ON IT IS NOW FLASHING U2 AND WILL NOT ALLOW ANY COPIES HOW CAN I FIX IT I replaced the Heater drum drive gear and assemlied the machine.Then I made 1copy before final assembly of rear cover and side cover. After fixing the side cover I tried one more time but now the machine shows '2' and 'H' alternately.
Can somebody assist me with this problem?
  • Rashid Hakim Sep 11, 2008
    No luck in getting rid of 'H' error. I thoroughly checked the connectors and the heater condition and it seems to be perfect. Now it show '3' and 'H' flashing alternately. I am stuck.
    May be someone can think of some solution.
    Problem Solver:
  • 13 Answers
Sounds like a loose connector. "H" code on Sharps indicate a heater fault, if I remember correctly "2" indicates it's a thermistor.
So, if it was working before you took it apart, I'd be looking at the connectors, good luck & happy hunting....
Posted on Sep 10, 2008
  • Mitch Schwartz
    Mitch Schwartz Sep 12, 2008
    Not your lucky day :(
    The H2 code was "Open Thermistor"
    The H3 code is "Fuser temperature too high"
    H4 code "Fuser temperature too low."
    Try a reset, if the problem is transient, it may or may not come back.
    To reset the above use CI0I14, This would be the order
    CLEAR
    INTERRUPT (also known as PAUSE or =)
    0
    INTERRUPT (at this point the display should go blank)
    14
    PRINT
    CLEAR (this should set the machine back to standby)
    Hope this works......
Error u2 ar163
EEFROM read write error.Clean motherboard
Apr 17, 2014 | Sharp AR 163 Copier
Copiadora sharp al1645cs aparecendo cod.u2
Press c photo c photo 16 press print key
Feb 10, 2010 | Sharp AL 1631 Copier
Having commercial photo copier sharp arb 320 having error code u2-11 on disply not able to print at all
Hello sir; Here is the way to reset it, the procedure as follow;
press "#", "*", "clear", "*", keys by orser,then enter 16 press start key then 00 press start again, that simple.
Oct 08, 2009 | Office Equipment & Supplies
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Communication error
I assume this is a sharp??????????
U2 Backup memory problem
Aug 25, 2008 | Office Equipment & Supplies
U2 CODE FLASHING ON PANEL
U2 is usually a memory type issue, have you unplug and then plug back in after 1 hr.
Jan 04, 2008 | Sharp AR-207 Copier
That is a E prom error. You will have to reset it with code 16.Go into the simulation mode.Press clear,interrupt,0,interrupt.Then press 16 and start.You will okay after that if not  opps bigger problem.
Oct 23, 2007 | Office Equipment & Supplies
167 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
