Question about Olympus FE-210 Digital Camera
No power Camera was not dropped or damaged. Hit the power button and nothing happens. Batteries are in correctly any ideas.
  • lernersr Sep 10, 2008
    While looking through pictures, lines appeared across the screen and it froze. I took the batteries out while the camera was still on and put new ones in. Camera will not function at all and the lens is still open.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
On power and picture issue, send to repair center.. it would appear that either the door is not making good contact or the battery compartment needs cleaning... after this then repair
the other problem appears to be the ccd and you could try reset through the menus
olympusamerica.com/repair
Posted on Oct 01, 2008
Why won't photo button won't do anything
Your camera will work with AA batteries.
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work.
Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
Jul 23, 2014 | FUJIFILM Instax 200 Instant Film Camera +...
New batteries still no power-up
Check the contact in the batt compartment for obstructions or corrosion etc. No power means broken circuitry - either physical dislodgement of electronic/ electrical parts or damaged electronic components.
Apr 01, 2013 | Canon Speedlite 430EX TTL Flash
Won't power up
Have you tried cleaning the battery contacts inside the camera? The problem that you describe is frequently due to a corrosion buildup that prevents the full power of the batteries from flowing to the camera. Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, then wipe both ends of the batteries and reinsert them into the camera. This cleaning clears the problem about 90% of the time, and I hope it works for you.
Sep 16, 2009 | Olympus Camedia C-725 Digital Camera
Lens Out...HELP ME!!!
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 12, 2009 | Sanyo Xacti VPC-S770 Digital Camera
When I move the on/off button to camera or book nothing happens..
You probably blew an internal fuse , get it checked by a professional. No user serviceable parts on this camera.
May 13, 2009 | Kodak EasyShare Z710 Digital Camera
I can't get my daughter's Hullabaloo working
Remove the batteries & press and hold the button again for 60 seconds. This will ensure that the capacitors in the unit fully discharge. Replace the batteries in the correct sequence and try to power on the unit again. Without further information (was the unit dropped, immersed in water, were the batteries ever put in incorrectly) I cannot offer you another solution.
Dec 23, 2008 | Cranium Hullabaloo Square Tin
Will not turn on
I had this same problem with my camera a few years back and took it into a camera store to get it fixed. It turned out that it was just the batteries I was using. You cant use regular AA batteries for this camera because they give too much power. If you just go to a walmart or target or anywhere like that, you can get AA camera batteries and that SHOULD solve the problem. let me know if that works.
Sep 14, 2008 | Sony Cyber-Shot DSC-S60 Digital Camera
Camera won't switch on
I thought the batteries had worn out because when I press the 'on' button the 'busy' light comes on for a few seconds and then goes out and nothing happens. Have changed batteries and checked installed correctly.
Any ideas please?
Jun 13, 2008 | Praktica SlimPix Digital Camera
Samsung S500 beeps and turns off when i hit shutter
If the Olympus is using the exact same batteries as the Canon, there is a high chance that the problem is with the batteries.
Dec 13, 2007 | Samsung Digimax S500 Digital Camera
Olympus FE-210 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
