Question about GE WBSE3120B Top Load Washer
Ge washer overflowing/not rinsing or wringing well
My ge top load washer is seven years old. About a year ago it started leaking from "somewhere" in auto soak mode. We stoped using auto soak and no problems till now. It is leaking out of the bottom of the overflow tube and is not rinsing suds out of the tub or wringing the water out of the clothes that well. I am glad to find this sight and hope you can help soon. If I dont get this fixxed soon I'll have to buy a new machine. I sure would rather order parts from some that can tell me what I need. thanks for your help
  • demyrobles Jul 04, 2008
    It's GE washing machine top load bought about five or six years ago.
    It spins but not rinse the water out of the load area and out of the machine. What could be the problem with this?
    Thank you so much
    President:
  • 3,130 Answers
If you need parts for any apliance go to www.repairclinic.com They will assist you to find the parts you need .
Posted on Mar 28, 2006
SOURCE:
My washing machin Lg 6.5kg Fuzzy Logic 10 years old is starting to play up, sometimes it overflows and the water doesnt stop, sometimes more often then not , it does not rinse or spin...what will it cost...
pressure switch is busted that controls the water stopping. no rinse or spin could be a couple of things main pcb or gearbox either way its expensive to fix i would be saving for a new one if i were you. there is a whirlpool commercial 7.5kg top load washer on the market its made in the usa this is the best machine for a family of seven i have this machine at my place (family of six) its a beast they have been making them the same way for 40 years and they last over 20 years they rust before they break.
Jan 09, 2011 | LG Washing Machines
Whirlpool ultimate care extra large, about 10 years old. when the machine is in spin cycle, it throws the circuit breaker. It started with a heavy load, but now it seems to do it all the time. It started...
Water leaking from tub seal into motor possibly? Try doing spin with dry newspaper under the machine and check for leaks. Could also possibly be water heater element loose or breaking down - leaks from drain hose or water pump body into windings? Dry news paper test should highlight where leaks are coming from.
!0 years old is ancient for a machine and you might consider replacement rather than a repair which will only be throwing good money after bad. Do you drive a 10 year old car? if you do, you expect repair bills to mount up! same with washer. I bet it doesn't owe you much!
Jan 03, 2018 | Whirlpool LSW9700P Top Load Washer
GE WSXH208FWW washer leaving spots on clothes
If you are getting round dark spots on your clothes after washing, the problem would be cause by a bearing seal leak. What happens is water leaks pass the seal into the bearings, and the grease leaks back into the wash water. To fix it would require the machine to be literally taken completely apart to get to the bearings. Very costly to repair. Sorry.
Aug 24, 2010 | GE WSXH208A Front Load Washer
Our GE WSERR417FOWW washer is leaking (profusely)
Any solution to your problem? I am searching because mine started the same behavior tonight. I hope that you found a solution, and would be willing to share it!
Thanks.
Jeff jeffyr2@verizon.net
May 24, 2010 | GE WJRR4170E Top Load Washer
How old is my washer? When were these made?
You need a serial number to tell for sure.
They probably stopped making those a few years ago.
And the oldest one I've seen it about 10 years old. So probably between 2-10 years old.
GE washer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | GE WJSE4150B Top Load Washer
Hi! GE top load washer model number wwse5240 is leaving grease stains inside the machine after laundering and of course on clothes. Not sure how old this machine is.
Your transmission is leaking oil. It's probably 10 to 15 years old for the transmission to be leaking. It can be replaced but it's not a small job. Part 320 in this diagram is your transmission. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5224109&diagram_id=22255027#d22255027
Jan 30, 2010 | GE WDSR2080D Top Load Washer
GE WBSE3120B Top Load Washer Logo
387 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
