Question about Canon ZR40 Mini DV Digital Camcorder
Stuck in "pause" mode
It was a good thought.....but it still is in the "pause" mode
  • 1 more comment
  • bgusman Sep 09, 2008
    When you flip the button to "camera" to start the recording process everything seems to be working....EXCEPT..........the screen shows the camera to be on "pause" mode and will not let me start the recording process
  • woodsy2069 May 09, 2009
    I have the same camera with the same problem. I think there is dust or chocolate milk (my kids use this camera, too) in the button mechanism. I have tried to clean it but no luck. The bright side is that you can use the cameras' remote to get the camera to record. It's a pain to carry the remote around, but at least I can still use the camera.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Bummer.  Is the pause mode on when it's recording of just durning playback?
  • Canon Master
  • 2,794 Answers
Hold the red button down for a couple of seconds on the right side of the camcorder.  Does the pause go away?
Posted on Sep 09, 2008
My neptune washer is stuck in pause mode I can't set it any any wash mode to wash a load the start/pause light just keeps blinking. Is there any way to reset it or boot it to get it started again thanks...
Karen,
Power it down by pulling the 120VAC power cord to the washer then plug back in and see if it will progress with the wash cycle. Which machine do you own the FAV6800A LED console display or the FAB9800A LCD console.
If still no good I will have you try to get into Service Mode but let’s see if a power cycle will clear the issue…….Rich
You will need the Service Manual for reference. Sears Parts Direct for reference.
May 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer stuck in pause mode
Check the door switch. I think you have posted twice.
Thanks/Mike
Oct 31, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Sansa Clip 8GB is stuck in pause mode
You mean it hangs up at pause mode and you can't turn off you device? if so, push up/press power button and hold for 10 to 20 seconds until the device turn off.
Then, turn on. if it' working. You should update new firmware.
Good luck
Jan 17, 2010 | SanDisk Sansa Clip MP3 Player
The washer is stuck in pause mode. How do I get
Control Lock To avoid having someone accidentally start or stop the washer, press Options and Select at the same time and hold for 10 seconds until “LOC” is displayed alternately with the estimated cycle time. To unlock the controls, press Options and Select at the same time and hold 10 seconds until ”LOC” is no longer displayed.
Sep 18, 2009 | Frigidaire Affinity ATF7000E Front Load...
Alpine cdm 7861 stuck in pause mode
Check for a "jammed" button. They use a little rubber membrane behind buttons and over time they do wear out. It is possible to push a button on the corner, make it shift enough to jam behind the faceplate & hard to see. Just push the button and see if it pops back like the rest of the buttons on the unit. If it still has a problem, post a comment and I will help you some more. Hope this helps
Jun 22, 2009 | Alpine CDM-7861 CD Player
Canon zr40 stuck in pause mode
Remove the battery.   Wait 10 seconds.  Put it back in and see if that resets it.
Sep 09, 2008 | Canon ZR40 Mini DV Digital Camcorder
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Stuck in Play-Pause mode.
Simply press REC/PAUSE to return to normal Playback mode.
Sep 06, 2005 | RCA CC-432 Camcorder
Canon ZR40 Mini DV Digital Camcorder Logo
131 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
