I can't uninstall a program. I go to Start, Control Panel, and then click uninstall and get a message saying it can't uninstall and to report error.
  • 2,794 Answers
Do you have an anti virus program in your computer?
If you do run it.  If you don't goto Microsoft.com and download the trial version of Windows One Care.
Posted on Sep 09, 2008
Printer not functioning properly,download software will no install, get error msg
What make of printer ?
What is the error message ?
click start control panel administrative tools computer management then select event viewer depending on what operating system you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if it's a program file you might uninstall the program restart your computer then reinstall some of these files/software if its driver related
you might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver disable uninstall or select properties again you will have the similiar options also you can troubleshoot the device
Mar 08, 2014 | Computers & Internet
C:/Progam Files/blocktards/unins000.dat what is this error and how do i fix it
Hello crouch8323,
Welcome to FixYa.Com!
Unins000.dat is a files that if used by Blocktards' uninstaller to properly uninstall Blocktards off of your Desktop. If your are trying to uninstall Blocktards and you are getting an error message, I recommend that you uninstall Blocktards from the Control Panel's Add & Remove Program (for Windows XP) or Programs & Features (for VISTA or 7). If you still have the same error message, you can also try uninstalling Blocktards by going to the Start Menu, All Programs, Blocktards, and click Uninstall. If these steps give you the same error message, you may need to use Blocktards installer to uninstall the game, see if running the installer gives you the option to modify, remove or repair. And if all else fails you can always use a 3rd party uninstaller software like the option found in CCleaner.
Regards,
Deathschythe33
Aug 22, 2011 | Computers & Internet
Cannot readf my E-MNail in Verizon Message Center; would like to uninstall the verizon message center
go to control panel
if you use windows xp go to "add remove program" click and at E-MNail in Verizon Message Center then click remove/change program, process will uninstall your E-MNail in Verizon Message Center wait until finish and your E-MNail in Verizon Message Center will uninstalled
if you use windows xp/vista at control panel double click "program and features" right click and at E-MNail in Verizon Message Center then click uninstall program, process will uninstall your E-MNail in Verizon Message Center, wait until finish and your E-MNail in Verizon Message Center will uninstalled
i hope this helpful
thank you for using fixya
Feb 11, 2011 | Dell Computers & Internet
Error message
There is a program attempting to run from that drive, apparently toy 2.)
I assume you are running Vista today (confirm).
Start button>in the search area type msconfig then click run
Click the startup tab disable (uncheck) any program labeled that.
remove the program
Start button>control panel>program add/remove> select the program and uninstall.
Jan 24, 2010 | Computers & Internet
Computer error problem
http://www.fixya.com/PostAnswer.aspx?thid=2692939
drea_mike67 on Jul 31, 2009
a message saying windows-no dis exception processing message c0000013 parameters 75b6bf9c 4 75b6bf9c 75b6bf9c then it says cancel try agin contunue and i push one and it just keeps coming back constantly.
Friday, July 31, 2009
Hello drea_mike67,
There may be any number of storage device faults causing the no disk exception error message. For instance, a usb device may have been removed without choosing the 'safely remove hardware' option. If that's the case then reconnect the usb device and choose 'safely remove hardware' (bottom right hand corner of your PC screen), and then remove the USB device.
If the error message still comes up then try using the device manager in the windows control panel like this:
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
In the Control Panel, do the following:
•Select System
•Select the Hardware tab
•Select Device Manager
•Look for disk drives or other drives that are not used or recognized...
•Right click the device(s) and select uninstall
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jul 31, 2009 | HP Computers & Internet
I am trying to remove a program from my computer. I click on :set program access& default,then I click on change or remove programs,but i have the error code 5001 and set up DLL.cpp (439)
if you want to remove programm on your PC click on start locate control panel the click on hard and remove programm then locate the programm you want to remove and remove it. by clicking on the programm then follow the instruction. after removing in the control panel go the drive C locate programm file then locate the file of the programm you uninstall.
Mar 05, 2009 | Computers & Internet
I was having problems with Sype not it has gone but an error came up 2330 how do I resolve this
fully uninstall skype from add or remove programs in the control panel. (start -> control panel -> add or remove programs)
then download skype from their website again and run the installation report back with results.
Dec 28, 2008 | Computers & Internet
I am trying to uninstall nero 7, I keep getting a message saying shellmanager missing or corrupt. I want to install nero 8 but I am unable to until I resolve this problem
Try uninstalling by clicking Start, Control Panel, Add or Removed Programs, select Nero 7, then click Remove, maybe that can solve your problem.
Oct 24, 2008 | Computers & Internet
Lime wire start error messages keep on coming back on my screen how to stop
Uninstall limeware from 'add/remove programs' in control panel (eventually reinstall it back later). Also check if there is limeware on start menu button / all program / startup. If there is click right mouse button and delete from startup folder.
Apr 21, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
