Question about GE Refrigerators
Ice door damper replacement
How do you replace a Door Recess Asembly damper
  • Anonymous Sep 10, 2008
    The dispenser is frosting up. What are the steps to replace the dispenser damper door?
  • 76 Answers
Just be more specific whith this,sorry im actualy afrikaans,i can help you but just tell me a bit more plz...
Posted on Sep 09, 2008
Damper in vent door opening and closing continuously
the vent damper opens and closes depending on the temperature
inside the fridge. You might try to change the temperature settings in the fridge and see if that helps
Mar 10, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
How to open ice/water dispenser on GE PSS26LSRDSS to replace ice door flap
TAKE SMALL SCREWDRIVER AND GENTLY PRY OFF DISPENSOR COVER, THEN UNPLUG 3 SETS OF WIRES FROM BOARD. THEN REMOVE 4 SCREWS HOLDING ON THE DOOR ACTIVATOR. DOOR RECESS THEN CAN BE REMOVED AND REPLACED.
EITHER UNPLUG UNIT OR OPEN FREEZER DOOR TO PREVENT ELECTRICAL SHOCK.IF OPENING DOOR KEEP DOOR OPEN WILL KILL POWER TO THE BOARD AREA.
Jan 17, 2013 | GE Refrigerators
Hi temp bit running
Hello Liz Hotelling - From what you have describes it sounds like the damper door might be open causing the temperature to be too cold. Use a mirror to look at damper door at the rear of compartment and use a hair dryer on damper door to deice for 5 to 10 minutes. Allow 24 hours and if the temperature is still too cold, then I would have a professional look at the damper door for replacement.
Nov 23, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Temperature in fridge is 32 degrees
If the model number above your post is correct the your model has a 67003411 Auto Damper9_26_2012_4_50_40_pm.jpgand if the damper door is all the way open causing the fresh food compartment to be flooded with freezing cold air from the freezer side. It is not uncommon for thes dampers to fail due to a leak in the thermostat on the side of coiled up on the damper. Look at damper t confirm there is no frost keeping the damper door open and if you like I will post how to examine by taking the damper out and placing the damper thermostat coil and dipping it into a glass of ice and a little water. The damper door should shut if dipped into ice water. If not the damper will need to be replaced in order for fresh food section temperatures to be regulated. I will be here should you have questions, Thanks Sea Breeze
Sep 25, 2012 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
My LG refrigerator is luke warm but my freezer is working properly. The set temperature is the suggested 4 level. 3 days ago, I had noticed that I had not closed the refrigerator doors properly for 12...
hello, first thing to check would be to assure that the evaporator fan motor located behind the rear inside wall of the freezer is blowing air. Following you assureing that the fan is working you would then go into the refrigerator and there is a small door called a damper door or in some units a diffuser door you would also assure that this door is not full of ice and is able to open and close. The cold air from the freezer comes through this damper door. If there is any ice build up on the door you may have to replace the damper door. I have found that trying to remove the ice that the door just never works properly after trying to defrost the door and is alot less troublesome to just replace the door if it was iced over or wasnt functioning properly. If you have any questions message me back I will await your reply and your finds in these two areas that I have mentioned. And if the fan is working and there is no ice on the damper door and it is opening and closeing I will continue pointing out other areas that may be the cause of the refrigerator not getting cold. Thank you
Rick
Sep 28, 2011 | Refrigerators
GE Profile refrigerator Model PFS22SISBSS is not cooling, the digital temp control is at 74 when I try to lower it will go to 34 then immediately back to 74. The fan and freezer are both working. A repair...
The problem is damper assembly.In the damper assembly there is a door.This door opens and close with the help of motor.The damper is located between freezer and fridge section.The cold air from freezer section enters to fridge section via this damper door.---------- What repairmen did was proper, but may be that door is not properly got open, it got closed again.Or there is ice got collected between the freezer and freezer section, so this is not letting the cool air to pass from freezer to fridge.----------- ---------- This damper assembly needs to be replaced.Actually this door functions correctly with motor.He open the damper door manually and thought, the cool air will enter the fridge section non stop, but that door is again got closed, by some how.--------- You will have to get the damper assembly part replaced, to get the air flow work properly.------- As the repair man has already ordered the part, otherwise you can get this parts from online sites like www.repairclinic.com or from sears parts direct site.-------- Getting the damper door assembly, replaced will help.Thanks.Helpmech.
Sep 08, 2011 | GE Profile Stainless Bottom-Freezer...
On my hotpoint frig/freezer, I do not have the water supply line hooked up, but it drips water into the pan of the door dispenser. Any thoughts?
The recess door in ice chute is sticking open. you need to replace the door and door selnoid. This a common problem.
Aug 21, 2011 | Hotpoint HSS25GFP Side by Side...
My GE Profile model psc23sgnabs leaks water from under the water & ice dispenser recess trim moulding. Is there any way to get the freezer door apart to replace water hose inside the door? There are...
No, the door is foamed together.
Remove small drip catch at bottom of dispenser area. Use silicone to seal recess along front edge and the two front corners. That should prevent water from getting under the door trim.
Mar 02, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Power locks work on all but 1 door
the latch asembly in the door locks the lock for that door u have to pull the interoir door panel and take out the electronic latch asembly and replace it
Aug 15, 2009 | 2005 Dodge Grand Caravan
GE Profile Arctica Side by Side with ice maker and water in door
Plz provide me with the full name and model of your appliance for there is a lot of diferent makes and sizes,plz reply asap so we can sort this problem out for you.
Thanks...
Wouter.
Sep 10, 2008 | Refrigerators
Refrigerators Logo
309 people viewed this question
Top Refrigerators Experts
KJ4QOB
Alan Moore
Level 1 Expert
Gerardo Ahuactzin
Gerardo Ahuactzin
Level 1 Expert
