Question about Kenmore 62622 Microwave Oven
63663 I have the F-9 fault on my Kenmore Elite Ultra Wave Microwave 63663 and I was wondering how hard it would be to replace the Magnatron. I'm a handy person, and want to do it myself. Were can I find the tech manual and for this microwave? Thanks Scott trips2318@yahoo.com
  • trips2318 Sep 11, 2008
    Did you do it yourself?? How hard is it to replace the inverter board???
    Thanks
The Magnatron is a major job and unless you first looked into or had the Inverter Board replaced, you are wasting your time. 90% of the F-9 problems fall into the Inverter solution, Try that 1st, it worked for us!! My Micro now works GREAT!!
Posted on Sep 11, 2008
  • Sanzonemd Sep 11, 2008
    Hi, If you look thru the Postings on this site, you will see that I like yourself was very miffed about this problem. If it was not for this site, I would have not known what was wrong. I had the Sears guy come and fix it. He spent about 1 hr from start to finish. I would strongly suggest that they do it. My question to you is, is it still under warranty? If it is and you change it yourself, your warranty is null and void. Check out if it is 1st. Good Luck, Debra
Kenmore elite microwave troubleshooting
My GE microwave buzzes at times but otherwise works just fine.
Jan 20, 2014 | Microwave Ovens
My Kenmore Elite Ultra Wave Technology microwave is displaying an F-9 error. What does that mean?
Here are a couple of quotes from another forum:
"Kenmore Elite 36 " over tne counter microwave is supplied by LG made by Gold Star, made in China. It's main problem is the high voltage inverter board supplyed by Sears Parts. If you get a F-9 code on your microwave display screen and the micro quits it's probably this board. Reset the machine by pulling the power plug and waiting an hour. If it is the high voltage board is at fault it will probably fail after 45 seconds of start up. This part is really hard to get at but is less than $100. A qualified technician should be able to remove and repair this item in less than hour. Some techs will quote you $300 labor, don't buy it, it should cost a $100 or less. No need to buy another microwave."
"F-9 on this microwave IS inverter related. There is a service tech troubleshooting document stuffed in behind the control board cover which has some testing proceedures. My problem was the magnatron and checked out bad with the help of this document. It would run for a few seconds making clicks and then say F-9. It has been working great since I replaced the magnatron PN 6324w1a002c."
Note that part numbers mentioned may not for your model.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
BUT once you have the part number from the Sears parts site, you can often get the parts cheaper here
May 25, 2010 | Kenmore 63662 / 63664 / 63669 Microwave...
Kenmore Ultra Wave Microwave has no power
after removing the cover of microwave chk for continuty of cavity thermostat usually calld TCO(thermal cut off). it is located on top of the cavity and circular in shape.usually neutral wire goes through this 2 control board and this TCO is for protection of cavity from overheating.if this tco is open.then replace it.usually this happens when u cook for 2 long.
Aug 15, 2009 | Goldstar MV-1515 Microwave Oven
Interior Microwave Light does not work
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number 721.63664300 at the Sears parts site.
May 11, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
9Fp and microwave cuts off
F-9 means the inverter board has failed. A bad magnatron can also cause this code. Recommend replace the Mag. and inverter board.
Feb 27, 2009 | Kenmore 62622 Microwave Oven
Kenmore 62622 Microwave Oven Logo
207 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
