Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon mp160 output feeder tray
I have broken off one of the small mounting tabs for my mp160 output
feeder tray. Can anyone advise where a replacement tray can be purchaseed?
eatc7402
  • 43 Answers
SOURCE: Canon MP160 Installation CD
Hi
is there a reason you require the cd?
did you know that you can install the printer by downloading the drivers from the canon website?
click here to be taken directly to the driver download page.
if the link does not work please go to: www.canon.com and search for your driver on there.
hope this helps.
Let me know if you require more assistance.
Posted on Nov 16, 2008
mdhasan
  • 25 Answers
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
549
Posted on Feb 27, 2009
ksdi
  • 34 Answers
SOURCE: Cannot find Correction Advice on Erroe E42 on Canon Printer aMP160Please advise
Fiend your solution direct from Canon. Here is your solution...
260
Posted on Mar 15, 2009
  • 118 Answers
SOURCE: I have a Canon Pixma
The answer to this question is yes you can do it but it is a messy complicated job. What it means is that the ink pads are full and need replacing. Sometimes you can reset the counter but I have found that it is not worth it as you could end up with ink flowing from the printer onto your carpet.
The simple answer is to replace the printer......They are so cheap today that it is not worth playing around with.
Posted on May 20, 2011
MedManHelp
  • 55 Answers
SOURCE: Canon mp160 plastic paper tray
To order an internal replacement part, please call 1-800-828-4040. The hours of operation are 9:00 A.M. to 8:00 P.M. EST from Monday to Friday. When calling, speak the term "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance.
For your information, below are examples of what constitutes an internal part Vs. a supply / accessory:
Examples of Parts:
  • Print Heads
  • Printer Paper Trays
  • Printer Paper Guides
  • Camera Battery Doors
  • Parts Only Assessable By Taking the Product Apart
Examples of Supplies / Accessories:
  • Ink Tanks
  • Battery Packs & Chargers
  • Most Power Adapters and Connecting Cables
  • Shoulder / Neck Straps
  • Bags and Cases
Posted on Aug 02, 2011
What does close the feeder tray mean
The Canon PIXMA iP4000 InkJet Printer has two paper sources for printing. Likely the top feeder tray is not completely closed (it is possible you do not have the printer set up to feed from both which may cause the error).
See the Quick Start Guide and the Picture Below:
Mar 06, 2013 | Canon PIXMA iP4000 InkJet Photo Printer
Hi, my Canon MP160 has issues with the auto paper feeder, or maybe the roller; I'm not sure. When it feeds paper, like 4 or 5 sheets go in at a time. I have followed the instructions to clean the...
Clean the separating pad (rectangular pad of rubber or cork on the bottom of the paper tray near the pickup roller) or it could be worn out (needs to be replaced) when cleaning rubber rollers and pads you need a rubber cleaner (do not use alcohol) it will dry out the rubber... you can also use RUBBER RENEU from M.G. Chemicals cat. no. 408A-250ML... a 250ml bottle is over kill but I use it to renue my car wipers also ha ha!...
Cheers!
Sep 18, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Canon mp160 plastic paper tray is broken. Can it be replaced?
Examples of Parts:
  • Print Heads
  • Ink Tanks
  • Bags and Cases
Aug 02, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Machine is saying "output tray full" no faxes
Open the fax. There is a small door that allows access to the fuser for jams. There is a little black tab to the right on the door. Reseat it so it is level and pivots freely. Close up machine should start faxing. This tab is a flag for a photointerupter. Is easily knocked out nof place.
Feb 17, 2011 | Canon LaserClass 2050 Plain Paper Fax
I have a printer canon inkjet mp140 and i don't know how to insert the paper from the tray that is down or from the upside tray
Well, you should insert the paper "from the upside tray". Follow these steps:
Align the edges of the paper before loading it;
Open the paper support of "the upside tray" and pull out the paper support extension;
Open the paper output tray ("tray that is down");
Adjust the position of the paper thickness lever;
Load the paper in the auto sheet feeder with the print side facing UP;
Align the paper stack against the right side of the auto sheet feeder.
Pinch the paper guide and slide it against the left side of the paper stack.
Nov 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I keep getting an alarm and it is saying document in ADF. There is nothing stuck in it, I've tried everything!
You could have a stuck or broken document edge sensor. There is usually a small lever that the document pushes down when you slide it into the feeder. This lever should move smoothly. If it is stuck down or broken the unit will think there is always a document in the feeder.
Some units have two sensor levers, one sensing the leading edge and one sensing the trailing edge when the document exits the feeder. If either one is stuck you could get a jam error. If both levers are working (if you can locate both of them) then one of the sensors may be bad (they are usually optical pair sensors inside the feeder housing). Of course, if the sensors are good and you still get an error the main board may be bad, but that is fairly unlikely.
Most likely is that there is something jammed into the feeder at the exit or where the document enters and it's pushing on one of the levers.
Sep 23, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Paper jammed under roller small piece of paper keep saying jam e3
Good day, I will give you the procedure how to clean the roller or canon pixma mp160.
Procedure:
1. Press [On/Off] to turn on the machine, then remove any paper from the auto sheet feeder.
2. press [maintenance] repeatedly until <b> appears.
3. press [black] or [color].
4. repeat steps 2 to 3 twice.
5. open the paper output tray.
6. load 3 or more A4 or letter-sized paper in the auto sheet feeder.
7. repeat steps 2 to 3 times.
the sheet paper is automatically fed in and then out of the machine.
have a nice day.
Aug 01, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My canon Pixma MP160 feeds too many sheets at one time. I have cleaned the rollers. It was printing beautifully not five minutes ago.
I recommend fanning your paper. Take the stack of paper from your input tray or feeder. Fan it like you would a deck of playing cards. This may help keep the leading edges of improperly cut paper from meshing to each other, resulting in feeding more than one sheet.
Dec 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
142 people viewed this question
old marine
old marine
