Question about Frigidaire ATF6000ES Front Load Washer
Door lock the lighton the front that tells you the door is not lit,replaced switch and that did not help.what else could i check?
  • 1 more comment
  • Anonymous Sep 30, 2008
    I have the Same problem with a E41 Code
  • exxonmobile May 17, 2009
    atf6000ES1 error code E51, anyone know the answer????????????/
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
To my knowledge, there are two (2) versions of a Frigidaire ATF6000ES Front Load Washer: a) ATF6000ES1 and b) ATF6000ES0, pls which one do you have?
If something is wrong with the washer, it could tell us the error codes and therefore would give us a general idea where to start the diagnosis. Other than the "Door Lock" is not lighted, anything else out of the ordinary? Or is the unit non-functional since it senses that the door is not lock and therefore would not engage any cycle?
To read the error codes, pls:
  • plug the washer to the mains;
  • wake the washer by pressing any button;
  • wait for a few seconds to stabilize the electronics/circuitry;
  • press and hold the Start/Pause and Cancel buttons simultaneously.
As long as the buttons are held, the failure code will appear in the display as an E followed by two (2) numbers, a number and a letter or two (2) letters. The control will beep and the Door Lock, Wash, Rinse and Final Spin indicators will flash. Pls note and postback the error code displayed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 10, 2008
Maytag 2000 drains all water and spins but spins slow
two things, first one is could be the r-11 resister on main board burned or a tub bearing . check the main board inside touch panel. on it is a resister that tells computer door lock is or is not latched door lock light may be lit but computer indicates not and will not advance to max spin. if resister is burned and board is replaced be sure that you replace the wax motor door lock motor as well. if you don't replace locking motor you risk burning out new board again. tub bearing is easy to find out. just lift basket at top with finger and feel for vertical movement of basket alone,"slop" or "movement up/down. if so then replace the rear tub shell and spinner for basket . hope this helps.
Apr 18, 2014 | Maytag Washing Machines
Wont start machine error come up
Door open error code can also be displayed as "dOE" On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
Apr 08, 2014 | LG WD-1280FHD Front Load Washer
E dl and the door will not open
F/dL error - Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
If all the connections are good replace the CCU.
This is a very common problem with Whirlpool duet front-loading washers and additional details you can find in this link: Whirpool DL_F_Code
Hope this helps (remember to rate this answer).
Aug 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My power mirrors and door locks on the drivers side stopped working. The door ajar icon is lit. Could is be a fuse? Where are they located?
If the door contact switch is broken or jammed, the ajar indicator will stay lit. This will also prevent the door locks from locking as a safety precaution to make sure you don't accidentally lock yourself out of the vehicle. Check the door contact switch first.
Mar 15, 2011 | 2004 Ford Explorer
Door lock indicator lit up but did not try to lock door. F90 err. After unplugging it for over 5 min and plugging it back in the door is still locked and will not unlock.
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jul 12, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Door lock failure
It sounds like your door lock unit has a bad wax motor. There are 2 wax motors on the unit. 1 which actually locks the door and 1 that presses down on a check switch to tell the computer board that the door is locked. The wax motor that is bad is the one that presses down on the check switch. It is not a part that can be replaced on its own and you will need to change the entire door lock unit
Jan 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Door open!
i had the same prob..and the cure was to change the bushes on the motor.its been fine since
Oct 28, 2008 | Whirlpool AWM6100 Front Load Washer
Hotpoint wd64 washer dryer
mits86 , you are correct - it could be the belt.
REMEMBER TO UNPLUG BEFORE STARTING ANYTHING!
To do the belt...
1. UNPLUG the washer.
2. check you've unplugged.
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic caps on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel.
If you see a broken belt then remove it and re-order one from hotpoint...see http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=634224&brand=&model=wd64&part=belt.
6. to replace belt - see motor shaft at bottom of unit. Dangle new belt round shaft of motor and gently pull so it does not come off motor.(This is not easy!)
7. At the same time Ease one side of the new belt back on to drive wheel on the back of the drum.
8. Turn Drive wheel until belt is on.(This is not easy and requires alot of hand strength)
9. Replace concrete block with bolt and spanner in reverse sequence you removed it.
10. replace lid, torx and cover for torx.
- If the belt is not broken in your case - it could be the brushes on the motor - I can give you info on this if required!
Please dont forget to rate me as fixya.
Mar 07, 2008 | Hotpoint Aquarius WD63 Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
358 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
