Question about Alpine MRV-T707 Car Audio Amplifier
No sound and some smoke
I have a alpine v12 mrv-t707 amp that i bought used and just installed. the wiring is correct as i have installed a couple amps before. when power is conected the green led comes on and some smoke billows from internally. it has the smell also. the green led comes on even without the remote wire connected. i am using smaller fuses to test it as i dont want to do too much damage in the troubleshooting process. what could the prob be? can you help!! chris
  • anthony18 Feb 08, 2009
    i have a alpine v12 mrv-t707 amp that i bought used.
    when
    also. what could the prob be? can you help!!
    Danny
    President:
  • 3,130 Answers
If you got smoke comming out its already has damage my friend.. Was this unit bench tested before you bought it or was it hooked up in another vehicle and you seen it work or did you buy it sight unheard??
Posted on Mar 24, 2006
Just want to know what speaker wattage matches my v12 mrv f705 85 rms x4 channel amplifier?
Use speakers that will handle 85 RMS continuous or higher wattage. I have 200 watt Rockford 6.5s on a 75 watt amp. They sound great with plenty of headroom if I go to a bigger amp.
Nov 20, 2012 | Alpine Car Audio & Video
Alpine Amplifier Cuts in and out on Passenger side while driving
Make sure wirings are not pinched and try replacing the fuse as well.
May 01, 2008 | Alpine MRV-F345 Car Audio Amplifier
Lost instruction manual mrv-100m v12 car amp
Hello hlanderson,
You can download a copy from Alpine's support vault here.
Hope this helps.
Aug 13, 2009 | Alpine Car Audio & Video
Alpine v12 amp no power
its your fuse box. i would bypass the fuse box and wire this amp directly to the battery via monster cable. make sure you attach a 30wieght fuse to the monster cable that is running from the battery to your amp. ground the amp against the trunk. scrape the paint of a section and drill a hole in the trunk. use this for the ground for you amp. this will fix the no power issue.
Feb 12, 2009 | Alpine MRV-T707 Car Audio Amplifier
Amp will not power on at all
did you use the exact parts? did you also replace the pwm controller
Sep 12, 2008 | Alpine MRV-F345 Car Audio Amplifier
Over heating problem
"how do i made amp ohm instead of 4"
What?
I think you're asking how to make the amp 2 ohm. If your 12's are already wired for 2 ohm, just connect the 2 leads to the bridged terminals on the amp. There will be 4 connections on the amp. One for each channel. Usually, the two outside terminals (one positive and one negative) are the bridge and it'll be noted with a line painted on the surface above the terminals. That's all you have to do.
If it is overheating, you should put cooling fans on it.
Aug 31, 2008 | Alpine MRV-T707 Car Audio Amplifier
V12 MRV-1507 or Xplod? Amplifier - XM-ZR1252 good quality sound
Alpine is just a better brand in general. I have the older MRV-1507, sounds GREAT, i have had friends who has had the Explode line, but it was always a temporary system until they got something better, like the alpine or kenwood.
Aug 14, 2008 | Car Audio & Video
Alpine MRV-T707 Car Audio Amplifier No Sound
disconnect all power (15min) try again with different speaker to see if sub is dammage.
Aug 22, 2007 | Alpine MRV-T707 Car Audio Amplifier
Alpine V12 MRV-T707
power wire from fuse block goes to "the 1 that says power"...remote is used to have your device turn another device on...like a cd changer
May 28, 2007 | Alpine MRV-T707 Car Audio Amplifier
this isnt a complex problem but both units may need service
Mar 12, 2007 | Alpine MRV-F345 Car Audio Amplifier
Car Audio & Video Logo
185 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
